[petsc-users] Block ILU with AIJ matrix?
Hong Zhang hzhang at mcs.anl.gov
Mon Oct 31 08:17:26 CDT 2011
>> Yes, modern direct solver do block factorization as super node method.
>> Can ASM type preconditioner use superlu ILUT on each subdomain?
> Yes.
Yes. Example
~petsc/src/ksp/ksp/examples/tutorials>mpiexec -n 2 ./ex2 -pc_type asm
-sub_pc_type ilu -sub_pc_factor_mat_solver_package superlu -ksp_view
Hong
>> At preset, my solver (BCGS) only works with ASM+ILU(1) on a "smart
>> partitioned" mesh.
>> > The ILUTP in SuperLU (4.2 and up) exploits blocking (supernodes) in
>> > the (approximate) L & U factors.  Note the block boundary is
>> > discovered on the fly, which is usually larger than the block size
>> > from the input matrix A.  So the efficiency is pretty good.  It uses
>> > threshold dropping with partial pivoting, numerically is quite good
>> > too.    It's available only in the serial version.
>> > Sherry Li
>> > On Sun, Oct 30, 2011 at 11:18 PM, Jed Brown <jedbrown at mcs.anl.gov>
>> > wrote:
>> > > On Sun, Oct 30, 2011 at 23:50, Gong Ding <gdiso at ustc.edu> wrote:
>> > >> I had also considered use max block size. But it is not efficient
>> > >> here.
>> > >> Hope petsc support nonuniform block size one day.
>> > > Inodes do a sort of partial blocking. There has to a clear performance
>> > > benefit to explicit variable blocking in order to justify the
>> > > implementation
>> > > and interface complexity. I have not yet seen a demonstration of this.
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
