[petsc-users] Error: Too many KSP monitors set
Dominik Szczerba
dominik at itis.ethz.ch
Fri Oct 21 09:05:37 CDT 2011
Unfortunately, I am still forced to use version 3.1. I will come back to
this issue after the upgrade to 3.2, which should be next week.
Many thanks,
Dominik
On Fri, Oct 21, 2011 at 3:28 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Dominik,
> This should not happen. Does this happen with petsc-3.2? Note that we
> are now supporting PETSc 3.2 and if the problem does not exist in 3.2 we
> will not fix it in 3.1. If it exists in 3.2 we will definitely fix it. Can
> you send us a small piece of code that exhibits this behavior or point to a
> PETSc example that exhibits this behavior so we can reproduce it and fix the
> error in 3.2
> Barry
> We have specific code that prevents the
> On Oct 21, 2011, at 4:18 AM, Dominik Szczerba wrote:
> > I am getting this error when performing a series of KSP solves. Removing
> "-ksp_monitor_true_residual" from options removes the error, but I would
> like to see the residues on screen.
> > I do not seem to find any functions in the docu to set max number of KSP
> monitors, but even if there is one - is it really wasteful to monitor each
> solve of my system?
> > Thanks,
> > Dominik
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Argument out of range!
> > [0]PETSC ERROR: Too many KSP monitors set!
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17 13:37:48
> CDT 2011
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111021/16c644f6/attachment.htm>
