[petsc-users] about make code with Petsc
behzad baghapour behzad.baghapour at gmail.com
Thu Oct 13 09:00:07 CDT 2011
Thanks.
On Thu, Oct 13, 2011 at 5:05 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Oct 13, 2011 at 8:21 AM, behzad baghapour <
> behzad.baghapour at gmail.com> wrote:
>> Dear all,
>> I want to create code objects in different folder like "object" but I
>> received "no rule to make target". The makefile is in the source files
>> folder.
>> Please tell me a hint for it.
> The PETSc make rules always put the *.o files in the same directory as the
> source. If you want then in a different place,
> you can put in an explicit 'mv' in your rule for the executable. There is
> also an experimental Python system, but I would
> not use it unless you have a lot of experience.
>   Thanks,
>      Matt
>> Here is my makefile:
>> SHELL=/bin/bash
>> OBJDIR   = object/
>> MYOBJ    = # my object files #
>> include ${PETSC_DIR}/conf/variables
>> include ${PETSC_DIR}/conf/rules
>> OBJLIST = $(addprefix $(OBJDIR), $(MYOBJ))
>> code: ${OBJLIST} chkopts
>>     -${CLINKER} -o code ${OBJLIST} ${INCDIR} ${PETSC_LIB}
>> Thanks,
>> Behzad Baghapour
>> Ph.D. Candidate, Mechecanical Engineering
>> University of Tehran, Tehran, Iran
>> https://sites.google.com/site/behzadbaghapour
>> Fax: 0098-21-88020741
> experiments lead.
> -- Norbert Wiener
Behzad Baghapour
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111013/83fdf988/attachment-0001.htm>
