[petsc-users] about make code with Petsc
Thu Oct 13 08:35:30 CDT 2011
On Thu, Oct 13, 2011 at 8:21 AM, behzad baghapour <
behzad.baghapour at gmail.com> wrote:
> Dear all,
> I want to create code objects in different folder like "object" but I
> received "no rule to make target". The makefile is in the source files
> folder.
> Please tell me a hint for it.
The PETSc make rules always put the *.o files in the same directory as the
source. If you want then in a different place,
you can put in an explicit 'mv' in your rule for the executable. There is
also an experimental Python system, but I would
not use it unless you have a lot of experience.
     Matt
> Here is my makefile:
> SHELL=/bin/bash
> OBJDIR   = object/
> MYOBJ    = # my object files #
> include ${PETSC_DIR}/conf/variables
> include ${PETSC_DIR}/conf/rules
> OBJLIST = $(addprefix $(OBJDIR), $(MYOBJ))
> code: ${OBJLIST} chkopts
>     -${CLINKER} -o code ${OBJLIST} ${INCDIR} ${PETSC_LIB}
> Thanks,
> Behzad Baghapour
> Ph.D. Candidate, Mechecanical Engineering
> University of Tehran, Tehran, Iran
> https://sites.google.com/site/behzadbaghapour
> Fax: 0098-21-88020741
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111013/ea2f27c7/attachment.htm>
