[petsc-users] about make code with Petsc
behzad baghapour behzad.baghapour at gmail.com
Thu Oct 13 09:04:43 CDT 2011
By the way. I can move the objects BUT when I remake the code all objects
are rebuilt again!!. Why when there is no need when objects are already
exist?
On Thu, Oct 13, 2011 at 5:30 PM, behzad baghapour <
behzad.baghapour at gmail.com> wrote:
> Thanks.
> On Thu, Oct 13, 2011 at 5:05 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Thu, Oct 13, 2011 at 8:21 AM, behzad baghapour <
>>> Dear all,
>>> I want to create code objects in different folder like "object" but I
>>> received "no rule to make target". The makefile is in the source files
>>> folder.
>>> Please tell me a hint for it.
>> The PETSc make rules always put the *.o files in the same directory as the
>> source. If you want then in a different place,
>> you can put in an explicit 'mv' in your rule for the executable. There is
>> also an experimental Python system, but I would
>> not use it unless you have a lot of experience.
>>   Thanks,
>>      Matt
>>> Here is my makefile:
>>> SHELL=/bin/bash
>>> OBJDIR   = object/
>>> MYOBJ    = # my object files #
>>> include ${PETSC_DIR}/conf/variables
>>> include ${PETSC_DIR}/conf/rules
>>> OBJLIST = $(addprefix $(OBJDIR), $(MYOBJ))
>>> code: ${OBJLIST} chkopts
>>>     -${CLINKER} -o code ${OBJLIST} ${INCDIR} ${PETSC_LIB}
>>> Thanks,
>>> Behzad Baghapour
>>> Ph.D. Candidate, Mechecanical Engineering
>>> University of Tehran, Tehran, Iran
>>> https://sites.google.com/site/behzadbaghapour
>>> Fax: 0098-21-88020741
>> experiments lead.
>> -- Norbert Wiener
> Behzad Baghapour
Behzad Baghapour
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111013/898b0568/attachment.htm>
