[petsc-users] Symmetric matrix filling
Alexander Grayver
agrayver at gfz-potsdam.de
Wed Nov 30 10:08:39 CST 2011
On 30.11.2011 16:22, Matthew Knepley wrote:
> On Wed, Nov 30, 2011 at 9:10 AM, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
> I'm not sure that MAT(S)BAIJ is what I need. My matrix symmetric,
> but not block.
> Well, I solve vector equations and there are 2-3 blocks (depending
> on the problem dimension), but this blocks normaly have size of >
> 10^5. So which block size should I specify to be efficient?
> Just use 1.
And for d_nz/o_nz also 1?
> Matt
> Regards,
> Alexander
> On 30.11.2011 14:27, Alexander Grayver wrote:
>> Thanks Matt!
>> Regards,
>> Alexander
>> On 30.11.2011 14:16, Matthew Knepley wrote:
>>> On Wed, Nov 30, 2011 at 3:43 AM, Alexander Grayver
>>> Hello,
>>> I'm trying to use mumps through PETSc now with symmetric
>>> matrix and cholesky factorization.
>>> When I use it directly I fill up only upper part of the
>>> matrix and set mumid%SYM = 2. Is that possible to follow
>>> same way with petsc?
>>> Which options do I have to choose?
>>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MATSBAIJ.html
>>> Matt
>>> Thanks in advance.
>>> Regards,
>>> Alexander
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to
>>> which their experiments lead.
>>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111130/c1bd227e/attachment.htm>
