[petsc-users] Symmetric matrix filling
Matthew Knepley
knepley at gmail.com
Wed Nov 30 10:13:35 CST 2011
On Wed, Nov 30, 2011 at 10:08 AM, Alexander Grayver <agrayver at gfz-potsdam.de
> wrote:
> On 30.11.2011 16:22, Matthew Knepley wrote:
> On Wed, Nov 30, 2011 at 9:10 AM, Alexander Grayver <
> agrayver at gfz-potsdam.de> wrote:
>> I'm not sure that MAT(S)BAIJ is what I need. My matrix symmetric, but
>> not block.
>> Well, I solve vector equations and there are 2-3 blocks (depending on the
>> problem dimension), but this blocks normaly have size of > 10^5. So which
>> block size should I specify to be efficient?
> Just use 1.
> And for d_nz/o_nz also 1?
No, preallocate for the nonzeros you enter, as normal.
Matt
> Matt
>> Regards,
>> Alexander
>> On 30.11.2011 14:27, Alexander Grayver wrote:
>> Thanks Matt!
>> Regards,
>> Alexander
>> On 30.11.2011 14:16, Matthew Knepley wrote:
>> On Wed, Nov 30, 2011 at 3:43 AM, Alexander Grayver <
>>> Hello,
>>> I'm trying to use mumps through PETSc now with symmetric matrix and
>>> cholesky factorization.
>>> When I use it directly I fill up only upper part of the matrix and set
>>> mumid%SYM = 2. Is that possible to follow same way with petsc?
>>> Which options do I have to choose?
>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MATSBAIJ.html
>> Matt
>>> Thanks in advance.
>>> Regards,
>>> Alexander
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111130/fb037022/attachment.htm>
