[petsc-users] Symmetric matrix filling
    Matthew Knepley
    knepley at gmail.com
    Wed Nov 30 09:22:00 CST 2011
On Wed, Nov 30, 2011 at 9:10 AM, Alexander Grayver
<agrayver at gfz-potsdam.de>wrote:
> I'm not sure that MAT(S)BAIJ is what I need. My matrix symmetric, but not
> block.
> Well, I solve vector equations and there are 2-3 blocks (depending on the
> problem dimension), but this blocks normaly have size of > 10^5. So which
> block size should I specify to be efficient?
Just use 1.
  Matt
> Regards,
> Alexander
> On 30.11.2011 14:27, Alexander Grayver wrote:
> Thanks Matt!
> Regards,
> Alexander
> On 30.11.2011 14:16, Matthew Knepley wrote:
> On Wed, Nov 30, 2011 at 3:43 AM, Alexander Grayver <
> agrayver at gfz-potsdam.de> wrote:
>> Hello,
>> I'm trying to use mumps through PETSc now with symmetric matrix and
>> cholesky factorization.
>> When I use it directly I fill up only upper part of the matrix and set
>> mumid%SYM = 2. Is that possible to follow same way with petsc?
>> Which options do I have to choose?
>  http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MATSBAIJ.html
>    Matt
>> Thanks in advance.
>> Regards,
>>  Alexander
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111130/5fe8e842/attachment.htm>
