[petsc-users] Symmetric matrix filling
Alexander Grayver agrayver at gfz-potsdam.de
Wed Nov 30 09:10:44 CST 2011
I'm not sure that MAT(S)BAIJ is what I need. My matrix symmetric, but
not block.
Well, I solve vector equations and there are 2-3 blocks (depending on
the problem dimension), but this blocks normaly have size of > 10^5. So
which block size should I specify to be efficient?
Alexander
On 30.11.2011 14:27, Alexander Grayver wrote:
> Thanks Matt!
> Regards,
> Alexander
> On 30.11.2011 14:16, Matthew Knepley wrote:
>> On Wed, Nov 30, 2011 at 3:43 AM, Alexander Grayver
>> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
>>     Hello,
>>     I'm trying to use mumps through PETSc now with symmetric matrix
>>     and cholesky factorization.
>>     When I use it directly I fill up only upper part of the matrix
>>     and set mumid%SYM = 2. Is that possible to follow same way with
>>     petsc?
>>     Which options do I have to choose?
>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MATSBAIJ.html
>>   Matt
>>     Thanks in advance.
>>     Regards,
>>     Alexander
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111130/0d58b487/attachment-0001.htm>
