[petsc-users] Assembling primal Schur matrix in FETI-DP method
Thomas Witkowski
Thomas.Witkowski at tu-dresden.de
Mon Nov 21 08:03:54 CST 2011
Zitat von Jed Brown <jedbrown at mcs.anl.gov>:
> On Mon, Nov 21, 2011 at 04:00, Thomas Witkowski <
> Thomas.Witkowski at tu-dresden.de> wrote:
>> Some technical question on this point: How can I explicitly factorize a
>> sequential matrix? Is MatLUFactor the correct function to do it?
> In general, I recommend using the KSP. You can KSPSetType(ksp,KSPPREONLY),
> PCSetType(pc,PCLU). Call KSPSolve() multiple times, the factorization will
> be reused. Or you can use MatLUFactor() directly if you really want.
Okay, but how to make use of the KSP in MatMatSolve?
