[petsc-users] Assembling primal Schur matrix in FETI-DP method
Thomas Witkowski
Thomas.Witkowski at tu-dresden.de
Mon Nov 21 08:12:40 CST 2011
Zitat von Thomas Witkowski <Thomas.Witkowski at tu-dresden.de>:
> Zitat von Jed Brown <jedbrown at mcs.anl.gov>:
>> On Mon, Nov 21, 2011 at 04:00, Thomas Witkowski <
>> Thomas.Witkowski at tu-dresden.de> wrote:
>>> Some technical question on this point: How can I explicitly factorize a
>>> sequential matrix? Is MatLUFactor the correct function to do it?
>> In general, I recommend using the KSP. You can KSPSetType(ksp,KSPPREONLY),
>> PCSetType(pc,PCLU). Call KSPSolve() multiple times, the factorization will
>> be reused. Or you can use MatLUFactor() directly if you really want.
> Okay, but how to make use of the KSP in MatMatSolve?
KSPGetOperators?
