[petsc-users] How to compile with DMDA
behzad baghapour
behzad.baghapour at gmail.com
Wed Nov 9 08:49:23 CST 2011
OK. I saw that my make file has a mistake :-)
But I have a question here. How I can find out the code runs in parallel as
the code hasn't get "rank" and "size" or not defined in main program maybe ?
Thanks, B.B.
On Wed, Nov 9, 2011 at 5:39 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 9, 2011 at 2:00 PM, behzad baghapour <
> behzad.baghapour at gmail.com> wrote:
>> Yes, I did mean it. But I received that error.
> 1) Do not type in the error. Cut & paste EXACTLY the error from the run
> 2) It sounds like you are trying to build without the PETSc makefiles.
> Since it is breaking,
> I recommend you use the makefiles instead. There is a section in the
> manual.
> Matt
>> On Wed, Nov 9, 2011 at 3:49 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> On Wed, 9 Nov 2011, behzad baghapour wrote:
>>> > Dear all,
>>> > It may be a repeated question. When I want to run an example with
>>> DMDA, I
>>> > received the error:
>>> > "could not find pestcdmda.h"
>>> ^^ you have a typo here..
>>> > I configured Petsc with --mpi-download=1, make a Petsc example with
>>> DMDA,
>>> ^^^^^^^^^^^ you mean --download-mpich?
>>> Satish
>>> > and run with mpiexec -n ....
>>> > What should I do more?
>>> > Thanks,
>>> > B.B.
>> Behzad Baghapour
>> Ph.D. Candidate, Mechecanical Engineering
>> University of Tehran, Tehran, Iran
>> https://sites.google.com/site/behzadbaghapour
>> Fax: 0098-21-88020741
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111109/a19eebf2/attachment.htm>
