[petsc-users] How to compile with DMDA
Matthew Knepley
knepley at gmail.com
Wed Nov 9 08:50:17 CST 2011
On Wed, Nov 9, 2011 at 2:49 PM, behzad baghapour <behzad.baghapour at gmail.com
> wrote:
> OK. I saw that my make file has a mistake :-)
> But I have a question here. How I can find out the code runs in parallel
> as the code hasn't get "rank" and "size" or not defined in main program
> maybe ?
-log_summary
Matt
> Thanks, B.B.
> On Wed, Nov 9, 2011 at 5:39 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Nov 9, 2011 at 2:00 PM, behzad baghapour <
>> behzad.baghapour at gmail.com> wrote:
>>> Yes, I did mean it. But I received that error.
>> 1) Do not type in the error. Cut & paste EXACTLY the error from the run
>> 2) It sounds like you are trying to build without the PETSc makefiles.
>> Since it is breaking,
>> I recommend you use the makefiles instead. There is a section in the
>> manual.
>> Matt
>>> On Wed, Nov 9, 2011 at 3:49 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>> On Wed, 9 Nov 2011, behzad baghapour wrote:
>>>> > Dear all,
>>>> > It may be a repeated question. When I want to run an example with
>>>> DMDA, I
>>>> > received the error:
>>>> > "could not find pestcdmda.h"
>>>> ^^ you have a typo here..
>>>> > I configured Petsc with --mpi-download=1, make a Petsc example with
>>>> DMDA,
>>>> ^^^^^^^^^^^ you mean --download-mpich?
>>>> Satish
>>>> > and run with mpiexec -n ....
>>>> > What should I do more?
>>>> > Thanks,
>>>> > B.B.
>>> Behzad Baghapour
>>> Ph.D. Candidate, Mechecanical Engineering
>>> University of Tehran, Tehran, Iran
>>> https://sites.google.com/site/behzadbaghapour
>>> Fax: 0098-21-88020741
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111109/f1e18126/attachment.htm>
