[petsc-users] How to compile with DMDA
Matthew Knepley
knepley at gmail.com
Wed Nov 9 08:09:10 CST 2011
On Wed, Nov 9, 2011 at 2:00 PM, behzad baghapour <behzad.baghapour at gmail.com
> wrote:
> Yes, I did mean it. But I received that error.
1) Do not type in the error. Cut & paste EXACTLY the error from the run
2) It sounds like you are trying to build without the PETSc makefiles.
Since it is breaking,
I recommend you use the makefiles instead. There is a section in the
manual.
Matt
> On Wed, Nov 9, 2011 at 3:49 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Wed, 9 Nov 2011, behzad baghapour wrote:
>> > Dear all,
>> > It may be a repeated question. When I want to run an example with DMDA,
>> I
>> > received the error:
>> > "could not find pestcdmda.h"
>> ^^ you have a typo here..
>> > I configured Petsc with --mpi-download=1, make a Petsc example with
>> DMDA,
>> ^^^^^^^^^^^ you mean --download-mpich?
>> Satish
>> > and run with mpiexec -n ....
>> > What should I do more?
>> > Thanks,
>> > B.B.
> Behzad Baghapour
> Ph.D. Candidate, Mechecanical Engineering
> University of Tehran, Tehran, Iran
> https://sites.google.com/site/behzadbaghapour
> Fax: 0098-21-88020741
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111109/8930418c/attachment.htm>
