[petsc-users] how to rebuild from updated repo
Mon Nov 7 15:56:42 CST 2011
  If you find that ./configure or the make are taking a huge amount of time you might investigate where the files are stored. If, for example, they are stored on a separate file server it may be most of the time is due to the file server. For example configuring and compiling each take me about 5 minutes on my laptop; on a desktop using a file server might take 1/2 an hour.
   Barry
On Nov 7, 2011, at 3:52 PM, Satish Balay wrote:
> On Mon, 7 Nov 2011, Shao-Ching Huang wrote:
>> Hi
>> I downloaded petsc using the "hg clone
>> http://petsc.cs.iit.edu/petsc/releases/petsc-3.2" method. Now, after
>> hg pull/update (some files are changed), do I always have to build
>> from scratch (i.e. compiling everything, including the --download-xxx
>> stuff)? Is there a short cut to rebuild libpetsc.{so,a} when I have no
>> configuration change?
> This is a tricky thing. Generally updates to petsc-3.2 should not
> require a rerun of configure or a rebuild of all library code - but
> this is not always true. [sometimes you might have to pull/update
> BuildSystem and rerun configure - or rebuild externalpackages - as the
> tarballs for these packages get updated].
> For the generaly case - an update of the libraries can be done with:
> [for cmake build]
> make
> [for non-cmake build]
> make ACTION=lib tree
> And if a rerun of configure is needed - one can run
> ./PETSC_ARCH/conf/reconfigure_PETSC_ARCH.py
> Satish
