[petsc-users] how to rebuild from updated repo
Shao-Ching Huang
huangsc at gmail.com
Mon Nov 7 16:07:52 CST 2011
Thanks guys.
I was thinking rebuilding in 5 seconds, if I could reuse most of the
already-built .o files. (Like in a typical makefile scenario -- only
the changed source files are re-compiled). It seems that the petsc
"make" command cleans up all the .o files automatically.
I have no problem of rebuilding the whole thing afresh. Actually that
is what I have been doing.
Shao-Ching
On Mon, Nov 7, 2011 at 1:56 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> If you find that ./configure or the make are taking a huge amount of time you might investigate where the files are stored. If, for example, they are stored on a separate file server it may be most of the time is due to the file server. For example configuring and compiling each take me about 5 minutes on my laptop; on a desktop using a file server might take 1/2 an hour.
> Barry
> On Nov 7, 2011, at 3:52 PM, Satish Balay wrote:
>> On Mon, 7 Nov 2011, Shao-Ching Huang wrote:
>>> Hi
>>> I downloaded petsc using the "hg clone
>>> http://petsc.cs.iit.edu/petsc/releases/petsc-3.2" method. Now, after
>>> hg pull/update (some files are changed), do I always have to build
>>> from scratch (i.e. compiling everything, including the --download-xxx
>>> stuff)? Is there a short cut to rebuild libpetsc.{so,a} when I have no
>>> configuration change?
>> This is a tricky thing. Generally updates to petsc-3.2 should not
>> require a rerun of configure or a rebuild of all library code - but
>> this is not always true. [sometimes you might have to pull/update
>> BuildSystem and rerun configure - or rebuild externalpackages - as the
>> tarballs for these packages get updated].
>> For the generaly case - an update of the libraries can be done with:
>> [for cmake build]
>> make
>> [for non-cmake build]
>> make ACTION=lib tree
>> And if a rerun of configure is needed - one can run
>> ./PETSC_ARCH/conf/reconfigure_PETSC_ARCH.py
>> Satish
