[petsc-users] VecView doesn't work properly with DA global vectors
Jed Brown jed at 59A2.org
Mon Mar 21 20:39:07 CDT 2011
You can set the "native" format to avoid doing this reordering.
http://www.mcs.anl.gov/petsc/petsc-2/snapshots/petsc-dev/docs/manualpages/Viewer/PetscViewerSetFormat.html
On Mar 22, 2011 2:28 AM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
On Mar 21, 2011, at 8:11 PM, Алексей Рязанов wrote:
> Hi
> Is it ok, that VecView doesn't work ...
  VecView() for DM global vectors present the vector entries in the global
natural ordering. Since PETSc divides the domain with DA into squareish
blocks when you print the values on a process (by calling DAVecGetArray) it
is not in the global natural ordering. Hence the two are different.
 Barry
> Thank you very much!
> Alexey Ryazanov.
> CODE:
> #include "petscksp.h"
> #incl...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110322/7c0a7527/attachment.htm>
