[petsc-users] VecView doesn't work properly with DA global vectors
Mon Mar 21 20:28:33 CDT 2011
On Mar 21, 2011, at 8:11 PM, Алексей Рязанов wrote:
> Hi
> Is it ok, that VecView doesn't work properly with vectors, obtained with DACreateGlobalVector function, or im doing something wrong?
> In my program I create 5x5 da and global vector, corresponding to this da.
> Then each of 4 process writes its rank to its own local elements using DAVecGet(Restore)Array functions.
> Then i use VecView to visualize my global vector.
> And i see, that each process owns elements with different values.
> Where is the mistake?
   VecView() for DM global vectors present the vector entries in the global natural ordering. Since PETSc divides the domain with DA into squareish blocks when you print the values on a process (by calling DAVecGetArray) it is not in the global natural ordering. Hence the two are different.
  Barry
> Thank you very much!
> Alexey Ryazanov.
> CODE:
> #include "petscksp.h"
> #include "petscda.h"
> static char help[] = "VecVeiw doesn't work properly with DAGlobalVectors";
> int main(int argc,char **args)
>   Vec		GlobalVec;
>   DA		da;
>   PetscInt	rank, dof, stencil_width, M, N, m, n, p, x, y, z, i, j;
>   PetscScalar	**array;
>   PetscErrorCode ierr;
>   PetscInitialize(&argc,&args,(char *)0,help);
>   MPI_Comm_rank(PETSC_COMM_WORLD, &rank);
>   M=N=5; dof=1; stencil_width=1;
>   ierr = DACreate2d(PETSC_COMM_WORLD, DA_NONPERIODIC, DA_STENCIL_BOX, M, N, PETSC_DECIDE, PETSC_DECIDE, dof, stencil_width, PETSC_NULL, PETSC_NULL, &da);
> 								CHKERRQ(ierr);
>   ierr = DACreateGlobalVector(da,&GlobalVec);			CHKERRQ(ierr);
>   ierr = DAGetCorners(da,&x,&y,&z,&m,&n,&p);			CHKERRQ(ierr);
>   ierr = DAVecGetArray(da, GlobalVec, &array);			CHKERRQ(ierr);
>   for(i=y; i<y+n ; i++)
>     for(j=x; j<x+m; j++)
> 	array[i][j]=rank;
>   ierr = DAVecRestoreArray(da, GlobalVec, &array);		CHKERRQ(ierr);
>   ierr = VecView(GlobalVec, PETSC_VIEWER_STDOUT_WORLD);		CHKERRQ(ierr);
>   ierr = VecDestroy(GlobalVec);					CHKERRQ(ierr);
>   ierr = DADestroy(da);	  					CHKERRQ(ierr);
>   ierr = PetscFinalize(); 					CHKERRQ(ierr);
>   return 0;
> OUTPUT:
> Process [0]
> 0
> 0
> 0
> 1
> 1
> 0
> 0
> 0
> 1
> Process [1]
> 1
> 0
> 0
> 0
> 1
> 1
> Process [2]
> 2
> 2
> 2
> 3
> 3
> 2
> Process [3]
> 2
> 2
> 3
> 3
