[petsc-users] VecView doesn't work properly with DA global vectors
Алексей Рязанов ram at ibrae.ac.ru
Mon Mar 21 20:11:02 CDT 2011
Hi
Is it ok, that VecView doesn't work properly with vectors, obtained with
DACreateGlobalVector function, or im doing something wrong?
In my program I create 5x5 da and global vector, corresponding to this da.
Then each of 4 process writes its rank to its own local elements
using DAVecGet(Restore)Array functions.
Then i use VecView to visualize my global vector.
And i see, that each process owns elements with different values.
Where is the mistake?
Thank you very much!
Alexey Ryazanov.
CODE:
#include "petscksp.h"
#include "petscda.h"
static char help[] = "VecVeiw doesn't work properly with DAGlobalVectors";
int main(int argc,char **args)
  Vec GlobalVec;
  DA da;
  PetscInt rank, dof, stencil_width, M, N, m, n, p, x, y, z, i, j;
  PetscScalar **array;
  PetscErrorCode ierr;
  PetscInitialize(&argc,&args,(char *)0,help);
  MPI_Comm_rank(PETSC_COMM_WORLD, &rank);
  M=N=5; dof=1; stencil_width=1;
  ierr = DACreate2d(PETSC_COMM_WORLD, DA_NONPERIODIC, DA_STENCIL_BOX, M, N,
PETSC_DECIDE, PETSC_DECIDE, dof, stencil_width, PETSC_NULL, PETSC_NULL,
&da);
CHKERRQ(ierr);
  ierr = DACreateGlobalVector(da,&GlobalVec); CHKERRQ(ierr);
  ierr = DAGetCorners(da,&x,&y,&z,&m,&n,&p); CHKERRQ(ierr);
  ierr = DAVecGetArray(da, GlobalVec, &array); CHKERRQ(ierr);
  for(i=y; i<y+n ; i++)
    for(j=x; j<x+m; j++)
array[i][j]=rank;
  ierr = DAVecRestoreArray(da, GlobalVec, &array); CHKERRQ(ierr);
  ierr = VecView(GlobalVec, PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
  ierr = VecDestroy(GlobalVec); CHKERRQ(ierr);
  ierr = DADestroy(da);   CHKERRQ(ierr);
  ierr = PetscFinalize(); CHKERRQ(ierr);
  return 0;
OUTPUT:
Process [0]
0
0
0
1
1
0
0
0
1
Process [1]
1
0
0
0
1
1
Process [2]
2
2
2
3
3
2
Process [3]
2
2
3
3
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110322/7d9e572d/attachment.htm>
