[petsc-users] Problem with Petcs link to window Intel MKl mkl_blas95.lib, mkl_lapack95.lib and mkl_blas_intelmpi.lib
Matthew Knepley
knepley at gmail.com
Mon Mar 21 11:31:23 CDT 2011
On Mon, Mar 21, 2011 at 10:26 AM, Hung Thanh Nguyen <
hung.thanh.nguyen at petrell.no> wrote:
> Dear Petcs user
> I havea problem to Install PETCs on windows Intel MKl –platform. During
> last 2-weeks I spent to build PETCs on window Intel mkl – compiler
> I try different configure –procedure, for example:
> *1)./config/configure.py --with-cc=’win32fe icc ‘ --with-fc=’win32fe
> ifort’ --with-cxx=’win32fe icpc’ -download-blas-lapack=1 *
> Got the error message
> Cannot run executables created with C. If this machine uses a batch system
> to submit jobs you witl need to configure ……………..with the assitional option
> –with-batch
> …Therefore, I try:
Your compilers do not appear to work in this shell. Can you compile a simple
program?
Matt
> *2)./config/configure.py –with-batch --with-cc=’win32fe icc ‘
> --with-fc=’win32fe ifort’ --with-cxx=’win32fe icpc’
> And got the error message
> Fortran compiler you provide with –with-fc=win32fe ifort does not work
> I am also try the other way to configure as
> *3) ./config/configure.py --with-cc='win32fe icc' --with-fc='win32fe
> ifort' --with-cxx='win32fe icc'*
> and I got the following error message:
> *Could not found C-compilers*
> *4)./config/configure.py –with-batch --with-cc='win32fe icl'
> --with-fc='win32fe ifort' --with-cxx='win32fe icl'
> --download-blas-lapack=1 *
> C compiler you provided with—cc=win32fe icl does not work
> *5)./config/configure.py --with-cc='win32fe icl' --with-fc='win32fe
> ifort' --with-cxx='win32fe icl' --download-blas-lapack=1*
> *6) ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe
> ifort' --with-cxx='win32fe cl' --download-f-blas-lapack=1*
> C compiler you provided with—cc=win32fe cl does not work
> (Please see configure.log file in attenment)
> I hope someone can give me some advise to solve this problem. Thanks very
> much
> Hung T. Nguyen
> Research in Numerical Analys
> University in Tromsø, Norway
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110321/6c7c6ce9/attachment.htm>
