[petsc-users] Problem with Petcs link to window Intel MKl mkl_blas95.lib, mkl_lapack95.lib and mkl_blas_intelmpi.lib
Hung Thanh Nguyen hung.thanh.nguyen at petrell.no
Mon Mar 21 10:26:23 CDT 2011
Dear Petcs user
I havea  problem to Install PETCs on windows Intel MKl -platform. During last 2-weeks  I  spent to build PETCs on window Intel mkl - compiler
I try different configure -procedure, for example:
1)./config/configure.py  --with-cc='win32fe icc '  --with-fc='win32fe ifort'   --with-cxx='win32fe icpc'   -download-blas-lapack=1
Got the error message
Cannot run executables created with C. If this machine uses a batch system to submit jobs you witl need to configure .................with the assitional option -with-batch
...Therefore, I try:
2)./config/configure.py -with-batch  --with-cc='win32fe icc '  --with-fc='win32fe ifort'   --with-cxx='win32fe icpc'   -download-blas-lapack=1
And got the error message
Fortran compiler you provide with -with-fc=win32fe ifort does not work
I am also try the other way to configure as
3) ./config/configure.py --with-cc='win32fe icc' --with-fc='win32fe ifort'  --with-cxx='win32fe icc'
and I got the following error message:
Could not found C-compilers
4)./config/configure.py -with-batch --with-cc='win32fe icl' --with-fc='win32fe ifort'  --with-cxx='win32fe icl'  --download-blas-lapack=1
C compiler you provided with-cc=win32fe icl does not work
5)./config/configure.py  --with-cc='win32fe icl' --with-fc='win32fe ifort'  --with-cxx='win32fe  icl'  --download-blas-lapack=1
6) ./config/configure.py  --with-cc='win32fe cl' --with-fc='win32fe ifort'  --with-cxx='win32fe  cl'  --download-f-blas-lapack=1
C compiler you provided with-cc=win32fe cl does not work
(Please see configure.log  file in attenment)
I hope someone can give me some  advise to solve  this problem. Thanks very much
Hung T. Nguyen
Research in Numerical Analys
University in Tromsø, Norway
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110321/25ca0c9d/attachment-0001.htm>
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110321/25ca0c9d/attachment-0001.obj>
