[petsc-users] -snes_type test
Jed Brown
jed at 59A2.org
Fri Mar 18 06:12:01 CDT 2011
On Fri, Mar 18, 2011 at 12:07, Gianluca Meneghello <gianmail at gmail.com>wrote:
> esting hand-coded Jacobian, if the ratio is
> O(1.e-8), the hand-coded Jacobian is probably correct.
> Run with -snes_test_display to show difference
> of hand-coded and finite difference Jacobian.
> Norm of matrix ratio 1.08967e-07 difference 2.43658e-07
> Norm of matrix ratio 7.6194e-08 difference 3.4075e-07
> Norm of matrix ratio 7.6211e-08 difference 3.40826e-07
Your Jacobian looks good so you don't need to use TEST.
> [0]PETSC ERROR: SNESSolve() line 2360 in src/snes/interface/snes.c
> [0]PETSC ERROR: main() line 144 in src/snes/examples/tutorials/ex1.c
> application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
> [unset]: aborting job:
This is intentional, the end of SNESSolve_Test() has
Return error code cause Jacobian not good
PetscFunctionReturn(PETSC_ERR_ARG_WRONGSTATE);
Perhaps it should be done differently, maybe even solve the Newton step and
continue, but that's not the current behavior.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110318/2d00ab2e/attachment.htm>
