[petsc-users] -snes_type test
Gianluca Meneghello gianmail at gmail.com
Fri Mar 18 06:41:09 CDT 2011
Thanks Jed.
One more thing: what does the three lines stand for then? I was
thinking it was three Newton steps, but I understand it's not...
The output I sent was actually the output of one of your examples. The
one from my own code is
Testing hand-coded Jacobian, if the ratio is
O(1.e-8), the hand-coded Jacobian is probably correct.
Run with -snes_test_display to show difference
of hand-coded and finite difference Jacobian.
Norm of matrix ratio 9.17257e-08 difference 2.58876e-05
Norm of matrix ratio 1.45865e-06 difference 0.000430034
Norm of matrix ratio 1.47148e-06 difference 0.000429436
[0]PETSC ERROR: SNESSolve() line 2361 in src/snes/interface/snes.c
[0]PETSC ERROR: main() line 71 in jactest.cpp
application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
[unset]: aborting job:
so I guess I have to look for an error somewhere!
Thanks again
Gianluca
On 18 March 2011 12:12, Jed Brown <jed at 59a2.org> wrote:
> On Fri, Mar 18, 2011 at 12:07, Gianluca Meneghello <gianmail at gmail.com>
>> Norm of matrix ratio 1.08967e-07 difference 2.43658e-07
>> Norm of matrix ratio 7.6194e-08 difference 3.4075e-07
>> Norm of matrix ratio 7.6211e-08 difference 3.40826e-07
> Your Jacobian looks good so you don't need to use TEST.
>> [0]PETSC ERROR: SNESSolve() line 2360 in src/snes/interface/snes.c
>> [0]PETSC ERROR: main() line 144 in src/snes/examples/tutorials/ex1.c
> This is intentional, the end of SNESSolve_Test() has
>          Return error code cause Jacobian not good
>   PetscFunctionReturn(PETSC_ERR_ARG_WRONGSTATE);
> Perhaps it should be done differently, maybe even solve the Newton step and
> continue, but that's not the current behavior.
"[Je pense que] l'homme est un monde qui vaut des fois les mondes et
que les plus ardentes ambitions sont celles qui ont eu l'orgueil de
l'Anonymat" -- Non omnibus, sed mihi et tibi
Amedeo Modigliani
