[petsc-users] MatMatMult takes much time
Barry Smith
bsmith at mcs.anl.gov
Sat Mar 12 08:54:25 CST 2011
A*B where A is sparse and B dense can be implemented efficiently since it is a bunch of sparse matrix vector products (one for each column of B)
S*G where S is dense is unlikley to ever be particularly fast: Here is how it is currently implemented
#undef __FUNCT__
#define __FUNCT__ "MatMatMultNumeric_MPIDense_MPIAIJ"
Computes (B'*A')' since computing B*A directly is untenable
n p p
m ( A ) * n ( B ) = m ( C )
PetscErrorCode MatMatMultNumeric_MPIDense_MPIAIJ(Mat A,Mat B,Mat C)
PetscErrorCode ierr;
Mat At,Bt,Ct;
PetscFunctionBegin;
ierr = MatTranspose(A,MAT_INITIAL_MATRIX,&At);CHKERRQ(ierr);
ierr = MatTranspose(B,MAT_INITIAL_MATRIX,&Bt);CHKERRQ(ierr);
ierr = MatMatMult(Bt,At,MAT_INITIAL_MATRIX,1.0,&Ct);CHKERRQ(ierr);
ierr = MatDestroy(At);CHKERRQ(ierr);
ierr = MatDestroy(Bt);CHKERRQ(ierr);
ierr = MatTranspose(Ct,MAT_REUSE_MATRIX,&C);CHKERRQ(ierr);
ierr = MatDestroy(Ct);CHKERRQ(ierr);
PetscFunctionReturn(0);
If you can suggest a way to implement it much more efficiently please let us know.
Are you sure you need this product and not A*B?
Barry
On Mar 12, 2011, at 8:17 AM, Alexander Grayver wrote:
> Hello,
> call MatMatMult(S,G,MAT_INITIAL_MATRIX,PETSC_DEFAULT_DOUBLE_PRECISION,J,ierr);CHKERRQ(ierr)
> I use this operation to compute matrix-matrix product. It's correct, but quite slow.
> For instance, my matrix S is a dense matrix size of <6x762048 complex double> and matrix G is a sparse matrix with 2 nonzeros per row and size of <762048x254016 complex double>
> Time spent on S*G was ~22 secs with 32 processes over 4 nodes. There is infiniband between nodes.
> Is it a real life or I'm doing something wrong?
> Regards,
> Alexander
