[petsc-users] MatMatMult takes much time
Alexander Grayver agrayver at gfz-potsdam.de
Sat Mar 12 09:06:49 CST 2011
On 12.03.2011 15:54, Barry Smith wrote:
>     A*B where A is sparse and B dense can be implemented efficiently since it is a bunch of sparse matrix vector products (one for each column of B)
>     S*G where S is dense is unlikley to ever be particularly fast: Here is how it is currently implemented
> #undef __FUNCT__
> #define __FUNCT__ "MatMatMultNumeric_MPIDense_MPIAIJ"
>      Computes (B'*A')' since computing B*A directly is untenable
Ok, it explains why the code:
               call MatTranspose(G,MAT_INITIAL_MATRIX,GT,ierr);CHKERRQ(ierr)
               call MatTranspose(S,MAT_INITIAL_MATRIX,ST,ierr);CHKERRQ(ierr)
               call
MatMatMult(GT,ST,MAT_INITIAL_MATRIX,PETSC_DEFAULT_DOUBLE_PRECISION,JT,ierr);CHKERRQ(ierr)
works faster than just
               call
MatMatMult(S,G,MAT_INITIAL_MATRIX,PETSC_DEFAULT_DOUBLE_PRECISION,J,ierr);CHKERRQ(ierr)
>                 n                       p                          p
>        m (      A       )  *  n (       B      )   =   m (         C        )
> PetscErrorCode MatMatMultNumeric_MPIDense_MPIAIJ(Mat A,Mat B,Mat C)
>    PetscErrorCode     ierr;
>    Mat                At,Bt,Ct;
>    PetscFunctionBegin;
>    ierr = MatTranspose(A,MAT_INITIAL_MATRIX,&At);CHKERRQ(ierr);
>    ierr = MatTranspose(B,MAT_INITIAL_MATRIX,&Bt);CHKERRQ(ierr);
>    ierr = MatMatMult(Bt,At,MAT_INITIAL_MATRIX,1.0,&Ct);CHKERRQ(ierr);
>    ierr = MatDestroy(At);CHKERRQ(ierr);
>    ierr = MatDestroy(Bt);CHKERRQ(ierr);
>    ierr = MatTranspose(Ct,MAT_REUSE_MATRIX,&C);CHKERRQ(ierr);
>    ierr = MatDestroy(Ct);CHKERRQ(ierr);
>    PetscFunctionReturn(0);
> If you can suggest a way to implement it much more efficiently please let us know.
> Are you sure you need this product and not A*B?
Unfortunately I can't suggest a better way. Well actually I need A*B,
but my initial matrices have to be transposed for that.
But probably there is a way to avoid forming dense matrix at all, this
way requires more code, that is why I tried another way with full dense
matrix first.
Thanks Barry.
>    Barry
> On Mar 12, 2011, at 8:17 AM, Alexander Grayver wrote:
>> Hello,
>> call MatMatMult(S,G,MAT_INITIAL_MATRIX,PETSC_DEFAULT_DOUBLE_PRECISION,J,ierr);CHKERRQ(ierr)
>> I use this operation to compute matrix-matrix product. It's correct, but quite slow.
>> For instance, my matrix S is a dense matrix size of<6x762048 complex double>  and matrix G is a sparse matrix with 2 nonzeros per row and size of<762048x254016 complex double>
>> Time spent on S*G was ~22 secs with 32 processes over 4 nodes. There is infiniband between nodes.
>> Is it a real life or I'm doing something wrong?
>> Regards,
>> Alexander
