[petsc-users] AOCreateBasic is not scaling
M. Scot Breitenfeld brtnfld at uiuc.edu
Mon Mar 7 11:39:27 CST 2011
On 03/04/2011 03:20 PM, Matthew Knepley wrote:
> On Fri, Mar 4, 2011 at 3:14 PM, M. Scot Breitenfeld <brtnfld at uiuc.edu
> <mailto:brtnfld at uiuc.edu>> wrote:
>     On 03/03/2011 12:18 PM, Matthew Knepley wrote:
>     > On Wed, Mar 2, 2011 at 4:52 PM, M. Scot Breitenfeld
>     <brtnfld at uiuc.edu <mailto:brtnfld at uiuc.edu>
>     > <mailto:brtnfld at uiuc.edu <mailto:brtnfld at uiuc.edu>>> wrote:
>     >     I don't number my global degree's of freedom from low-high
>     >     continuously
>     >     per processor as PETSc uses for ordering, but I use the natural
>     >     ordering
>     >     of the application, I then use AOcreateBasic to obtain the
>     mapping
>     >     between the PETSc and my ordering.
>     > I would suggest using the LocalToGlobalMapping functions, which are
>     > scalable.
>     > AO is designed for complete global permutations.
>     I don't understand how I can avoid not using AO if my global dof per
>     processor are not arranged in PETSc global ordering (continuous row
>     ordering, i.e. proc1_ 0-n, proc2_n+1:m, proc3_m+1:p, etc...). In the
>     LocalToGlobalMapping routines, doesn't the "GlobalMapping" part mean
>     PETSc ordering and not my application's ordering.
>     I thought I understood the difference between AO and
>     LocalToGlobalMapping but now I'm confused. I tried to use the
>     LocalToGlobalMapping routines and the solution values are correct but
>     the ordering corresponds the global node ordering, not how I
>     partitioned
>     the mesh. In other words, the values are returned in the same ordering
>     as for a serial run, which makes sense since this is how PETSc orders
>     the rows. If I had used PETSc ordering then this would be fine.
>     Is the moral of the story, if I want to get scalability I need to
>     rearrange my global dof in PETSc ordering so that I can use
>     LocalToGlobalMapping?
> I am having a really hard time understanding what you want? If you
> want Natural
> Ordering or any other crazy ordering on input/output go ahead and use
> AO there
> because the non-scalability is amortized over the run. The PETSc
> ordering should
> be used for all globally assembled structures in the solve because its
> efficient, and
> there is no reason for the user to care about these structures. For
> integration/assembly,
> use local orderings since that is all you need for a PDE. If you have
> an exotic
> equation that really does need global information, I would like to
> hear about it, but
> it would most likely be non-scalable on its own.
I don't think I'm doing anything crazy, just probably a misunderstanding
on my part, I'll try to explain it again:
Take this 1D example (dof matches the node numbering) where 'o' are nodes
Global--0********4********3********1********2********5
______o--------o--------o--------o--------o--------o
Local---0********1********2********0********1********2
______|------PROC0---------|-------PROC1-----------|
PROC0: indices = 0,4,3, input = 0, 1, 2
PROC1: indices = 1,2,5, input = 0, 1, 2
CALL ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD, 3, indices, mapping,
ierr)
CALL ISLocalToGlobalMappingApply(mapping,3,input,output,ierr)
PROC0: output = 0,4,3, input = 0,1,2
PROC1: output = 1,2,5, input = 0,1,2
CALL VecCreateMPI(PETSC_COMM_WORLD,3, 6, b,ierr)
CALL MatCreateMPISBAIJ(PETSC_COMM_WORLD, 1, &
       3, 3, &
       6, 6, &
       0, d_nnz, 0, o_nnz, A, ierr)
CALL MatSetLocalToGlobalMapping(A, mapping, ierr)
CALL VecSetLocalToGlobalMapping(b, mapping, ierr)
... use MatSetValuesLocal, VecSetValuesLocal to fill arrays.
... solve and place solution in 'b' vector
Now it is my understanding that when I use VecGetValues (and is also
what I observe)
PROC0: b will have solutions for global nodes 0,1,2
PROC1: b will have solutions for global nodes 3,4,5
But, I would like to have,
PROC0: b will have solutions for global nodes 0,4,3
PROC1: b will have solutions for global nodes 1,2,5
It is my understanding that I either need to use AO to get the
these values, or I should have renumber the nodes such that,
Global--0********1********2********3********4********5
Scot
>     Matt
>     >   Thanks,
>     >      Matt
>     >      CALL VecGetOwnershipRange(b, low, high, ierr)
>     >      icnt = 0
>     >      DO mi = 1, mctr ! these are the nodes local to processor
>     >            mi_global = myglobal(mi)
>     >            irowx = 3*mi_global-2
>     >            irowy = 3*mi_global-1
>     >            irowz = 3*mi_global
>     >            mappings(icnt+1:icnt+3) = (/            &
>     >                 nrow_global(row_from_dof(1,mi))-1, &
>     >                 nrow_global(row_from_dof(2,mi))-1, &
>     >                 nrow_global(row_from_dof(3,mi))-1  &
>     >            petscOrdering(icnt+1:icnt+3) =
>     >     (/low+icnt,low+icnt+1,low+icnt+2/)
>     >            icnt = icnt + 3
>     >      END DO
>     >      CALL AOCreateBasic(PETSC_COMM_WORLD, icnt, mappings,
>     petscOrdering,
>     >     toao, ierr)
>     >      DO mi = mctr+1, myn ! these are the ghost nodes not on this
>     processor
>     >         icnt = icnt + 3
>     >      ENDDO
>     >      CALL AOApplicationToPetsc(toao, 3*myn, mappings, ierr)
>     >      CALL AODestroy(toao, ierr)
>     >     I then use  mapping to input the values into the correct row
>     as wanted
>     >     by PETSc
>     >     On 03/02/2011 04:29 PM, Matthew Knepley wrote:
>     >     > On Wed, Mar 2, 2011 at 4:25 PM, M. Scot Breitenfeld
>     <mailto:brtnfld at uiuc.edu <mailto:brtnfld at uiuc.edu>>>> wrote:
>     >     >     Hi,
>     >     >     First, thanks for the suggestion on using MPISBAIJ for
>     my A
>     >     matrix, it
>     >     >     seems to have cut down on my memory and assembly time.
>     For a 1.5
>     >     >     million
>     >     >     dof problem:
>     >     >        # procs:                  2        4        8
>         16
>     >     >     Assembly (sec):        245     124      63       86
>     >     >     Solver (sec):              924     578     326     680
>     >     >     Memory (GB):          2.5        1.4     .877    .565
>     >     >     The problem I have is the amount of time it's taking in
>     >     AOCreateBasic,
>     >     >     it takes longer then assembling,
>     >     >        # procs:                            2        4        8
>     >           16
>     >     >     AOCreateBasic (sec):         .6      347      170     197
>     >     >     Is there something that I can change or something I
>     can look
>     >     for that
>     >     >     might be causing this increase in time as I go from 2 to 4
>     >     processors
>     >     >     (at least it scales from 4 to 8 processors). I read in the
>     >     archive
>     >     >     that
>     >     >     AOCreateBasic is not meant to be scalable so maybe
>     there is
>     >     nothing I
>     >     >     can do.
>     >     > Yes, this is non-scalable. What are you using it for?
>     >     >    Matt
>     >     >     Thanks,
>     >     >     Scot
>     >     > What most experimenters take for granted before they begin
>     their
>     >     > experiments is infinitely more interesting than any
>     results to which
>     >     > their experiments lead.
>     >     > -- Norbert Wiener
>     > What most experimenters take for granted before they begin their
>     > experiments is infinitely more interesting than any results to which
>     > -- Norbert Wiener
> -- Norbert Wiener
