[petsc-users] AOCreateBasic is not scaling
Mon Mar 7 11:57:52 CST 2011
On Mon, Mar 7, 2011 at 11:39 AM, M. Scot Breitenfeld <brtnfld at uiuc.edu>wrote:
> On 03/04/2011 03:20 PM, Matthew Knepley wrote:
> > On Fri, Mar 4, 2011 at 3:14 PM, M. Scot Breitenfeld <brtnfld at uiuc.edu
> > <mailto:brtnfld at uiuc.edu>> wrote:
> >     On 03/03/2011 12:18 PM, Matthew Knepley wrote:
> >     > On Wed, Mar 2, 2011 at 4:52 PM, M. Scot Breitenfeld
> >     <brtnfld at uiuc.edu <mailto:brtnfld at uiuc.edu>
> >     > <mailto:brtnfld at uiuc.edu <mailto:brtnfld at uiuc.edu>>> wrote:
> >     >     I don't number my global degree's of freedom from low-high
> >     >     continuously
> >     >     per processor as PETSc uses for ordering, but I use the natural
> >     >     ordering
> >     >     of the application, I then use AOcreateBasic to obtain the
> >     mapping
> >     >     between the PETSc and my ordering.
> >     > I would suggest using the LocalToGlobalMapping functions, which are
> >     > scalable.
> >     > AO is designed for complete global permutations.
> >     I don't understand how I can avoid not using AO if my global dof per
> >     processor are not arranged in PETSc global ordering (continuous row
> >     ordering, i.e. proc1_ 0-n, proc2_n+1:m, proc3_m+1:p, etc...). In the
> >     LocalToGlobalMapping routines, doesn't the "GlobalMapping" part mean
> >     PETSc ordering and not my application's ordering.
> >     I thought I understood the difference between AO and
> >     LocalToGlobalMapping but now I'm confused. I tried to use the
> >     LocalToGlobalMapping routines and the solution values are correct but
> >     the ordering corresponds the global node ordering, not how I
> >     partitioned
> >     the mesh. In other words, the values are returned in the same
> ordering
> >     as for a serial run, which makes sense since this is how PETSc orders
> >     the rows. If I had used PETSc ordering then this would be fine.
> >     Is the moral of the story, if I want to get scalability I need to
> >     rearrange my global dof in PETSc ordering so that I can use
> >     LocalToGlobalMapping?
> > I am having a really hard time understanding what you want? If you
> > want Natural
> > Ordering or any other crazy ordering on input/output go ahead and use
> > AO there
> > because the non-scalability is amortized over the run. The PETSc
> > ordering should
> > be used for all globally assembled structures in the solve because its
> > efficient, and
> > there is no reason for the user to care about these structures. For
> > integration/assembly,
> > use local orderings since that is all you need for a PDE. If you have
> > an exotic
> > equation that really does need global information, I would like to
> > hear about it, but
> > it would most likely be non-scalable on its own.
> I don't think I'm doing anything crazy, just probably a misunderstanding
> on my part, I'll try to explain it again:
> Take this 1D example (dof matches the node numbering) where 'o' are nodes
> Global--0********4********3********1********2********5
> ______o--------o--------o--------o--------o--------o
> Local---0********1********2********0********1********2
> ______|------PROC0---------|-------PROC1-----------|
> PROC0: indices = 0,4,3, input = 0, 1, 2
> PROC1: indices = 1,2,5, input = 0, 1, 2
> CALL ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD, 3, indices, mapping,
> ierr)
> CALL ISLocalToGlobalMappingApply(mapping,3,input,output,ierr)
> PROC0: output = 0,4,3, input = 0,1,2
> PROC1: output = 1,2,5, input = 0,1,2
> CALL VecCreateMPI(PETSC_COMM_WORLD,3, 6, b,ierr)
> CALL MatCreateMPISBAIJ(PETSC_COMM_WORLD, 1, &
>       3, 3, &
>       6, 6, &
>       0, d_nnz, 0, o_nnz, A, ierr)
> CALL MatSetLocalToGlobalMapping(A, mapping, ierr)
> CALL VecSetLocalToGlobalMapping(b, mapping, ierr)
> ... use MatSetValuesLocal, VecSetValuesLocal to fill arrays.
> ... solve and place solution in 'b' vector
> Now it is my understanding that when I use VecGetValues (and is also
> what I observe)
> PROC0: b will have solutions for global nodes 0,1,2
> PROC1: b will have solutions for global nodes 3,4,5
> But, I would like to have,
> PROC0: b will have solutions for global nodes 0,4,3
> PROC1: b will have solutions for global nodes 1,2,5
> It is my understanding that I either need to use AO to get the
> these values, or I should have renumber the nodes such that,
Yes, however the global numbering during a solve is really only
important to the PETSc internals, and it designed to be efficient.
You can use AO for global reordering on input/output. As I said,
this is amortized over the entire computation, and thus some
non-scalability is usually no problem. If it is, consider renumbering
because the entire solve would run slowly with an arbitrary global
ordering.
   Matt
> Global--0********1********2********3********4********5
> Scot
> >     Matt
> >     >   Thanks,
> >     >      Matt
> >     >      CALL VecGetOwnershipRange(b, low, high, ierr)
> >     >      icnt = 0
> >     >      DO mi = 1, mctr ! these are the nodes local to processor
> >     >            mi_global = myglobal(mi)
> >     >            irowx = 3*mi_global-2
> >     >            irowy = 3*mi_global-1
> >     >            irowz = 3*mi_global
> >     >            mappings(icnt+1:icnt+3) = (/            &
> >     >                 nrow_global(row_from_dof(1,mi))-1, &
> >     >                 nrow_global(row_from_dof(2,mi))-1, &
> >     >                 nrow_global(row_from_dof(3,mi))-1  &
> >     >            petscOrdering(icnt+1:icnt+3) =
> >     >     (/low+icnt,low+icnt+1,low+icnt+2/)
> >     >            icnt = icnt + 3
> >     >      END DO
> >     >      CALL AOCreateBasic(PETSC_COMM_WORLD, icnt, mappings,
> >     petscOrdering,
> >     >     toao, ierr)
> >     >      DO mi = mctr+1, myn ! these are the ghost nodes not on this
> >     processor
> >     >         icnt = icnt + 3
> >     >      ENDDO
> >     >      CALL AOApplicationToPetsc(toao, 3*myn, mappings, ierr)
> >     >      CALL AODestroy(toao, ierr)
> >     >     I then use  mapping to input the values into the correct row
> >     as wanted
> >     >     by PETSc
> >     >     On 03/02/2011 04:29 PM, Matthew Knepley wrote:
> >     >     > On Wed, Mar 2, 2011 at 4:25 PM, M. Scot Breitenfeld
> >     <mailto:brtnfld at uiuc.edu <mailto:brtnfld at uiuc.edu>>>> wrote:
> >     >     >     Hi,
> >     >     >     First, thanks for the suggestion on using MPISBAIJ for
> >     my A
> >     >     matrix, it
> >     >     >     seems to have cut down on my memory and assembly time.
> >     For a 1.5
> >     >     >     million
> >     >     >     dof problem:
> >     >     >        # procs:                  2        4        8
> >         16
> >     >     >     Assembly (sec):        245     124      63       86
> >     >     >     Solver (sec):              924     578     326     680
> >     >     >     Memory (GB):          2.5        1.4     .877    .565
> >     >     >     The problem I have is the amount of time it's taking in
> >     >     AOCreateBasic,
> >     >     >     it takes longer then assembling,
> >     >     >        # procs:                            2        4
>  8
> >     >           16
> >     >     >     AOCreateBasic (sec):         .6      347      170     197
> >     >     >     Is there something that I can change or something I
> >     can look
> >     >     for that
> >     >     >     might be causing this increase in time as I go from 2 to
> 4
> >     >     processors
> >     >     >     (at least it scales from 4 to 8 processors). I read in
> the
> >     >     archive
> >     >     >     that
> >     >     >     AOCreateBasic is not meant to be scalable so maybe
> >     there is
> >     >     nothing I
> >     >     >     can do.
> >     >     > Yes, this is non-scalable. What are you using it for?
> >     >     >    Matt
> >     >     >     Thanks,
> >     >     >     Scot
> >     >     > What most experimenters take for granted before they begin
> >     their
> >     >     > experiments is infinitely more interesting than any
> >     results to which
> >     >     > their experiments lead.
> >     >     > -- Norbert Wiener
> >     > What most experimenters take for granted before they begin their
> >     > experiments is infinitely more interesting than any results to
> which
> >     > -- Norbert Wiener
> > experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110307/d5da248d/attachment-0001.htm>
