[petsc-users] AOCreateBasic is not scaling
Matthew Knepley
knepley at gmail.com
Fri Mar 4 15:20:06 CST 2011
On Fri, Mar 4, 2011 at 3:14 PM, M. Scot Breitenfeld <brtnfld at uiuc.edu>wrote:
> On 03/03/2011 12:18 PM, Matthew Knepley wrote:
> > On Wed, Mar 2, 2011 at 4:52 PM, M. Scot Breitenfeld <brtnfld at uiuc.edu
> > <mailto:brtnfld at uiuc.edu>> wrote:
> > I don't number my global degree's of freedom from low-high
> > continuously
> > per processor as PETSc uses for ordering, but I use the natural
> > ordering
> > of the application, I then use AOcreateBasic to obtain the mapping
> > between the PETSc and my ordering.
> > I would suggest using the LocalToGlobalMapping functions, which are
> > scalable.
> > AO is designed for complete global permutations.
> I don't understand how I can avoid not using AO if my global dof per
> processor are not arranged in PETSc global ordering (continuous row
> ordering, i.e. proc1_ 0-n, proc2_n+1:m, proc3_m+1:p, etc...). In the
> LocalToGlobalMapping routines, doesn't the "GlobalMapping" part mean
> PETSc ordering and not my application's ordering.
> I thought I understood the difference between AO and
> LocalToGlobalMapping but now I'm confused. I tried to use the
> LocalToGlobalMapping routines and the solution values are correct but
> the ordering corresponds the global node ordering, not how I partitioned
> the mesh. In other words, the values are returned in the same ordering
> as for a serial run, which makes sense since this is how PETSc orders
> the rows. If I had used PETSc ordering then this would be fine.
> Is the moral of the story, if I want to get scalability I need to
> rearrange my global dof in PETSc ordering so that I can use
> LocalToGlobalMapping?
I am having a really hard time understanding what you want? If you want
Natural
Ordering or any other crazy ordering on input/output go ahead and use AO
there
because the non-scalability is amortized over the run. The PETSc ordering
should
be used for all globally assembled structures in the solve because its
efficient, and
there is no reason for the user to care about these structures. For
integration/assembly,
use local orderings since that is all you need for a PDE. If you have an
exotic
equation that really does need global information, I would like to hear
about it, but
it would most likely be non-scalable on its own.
Matt
> > Thanks,
> > Matt
> > CALL VecGetOwnershipRange(b, low, high, ierr)
> > icnt = 0
> > DO mi = 1, mctr ! these are the nodes local to processor
> > mi_global = myglobal(mi)
> > irowx = 3*mi_global-2
> > irowy = 3*mi_global-1
> > irowz = 3*mi_global
> > mappings(icnt+1:icnt+3) = (/ &
> > nrow_global(row_from_dof(1,mi))-1, &
> > nrow_global(row_from_dof(2,mi))-1, &
> > nrow_global(row_from_dof(3,mi))-1 &
> > petscOrdering(icnt+1:icnt+3) =
> > (/low+icnt,low+icnt+1,low+icnt+2/)
> > icnt = icnt + 3
> > END DO
> > CALL AOCreateBasic(PETSC_COMM_WORLD, icnt, mappings, petscOrdering,
> > toao, ierr)
> > DO mi = mctr+1, myn ! these are the ghost nodes not on this
> processor
> > icnt = icnt + 3
> > ENDDO
> > CALL AOApplicationToPetsc(toao, 3*myn, mappings, ierr)
> > CALL AODestroy(toao, ierr)
> > I then use mapping to input the values into the correct row as
> wanted
> > by PETSc
> > On 03/02/2011 04:29 PM, Matthew Knepley wrote:
> > > On Wed, Mar 2, 2011 at 4:25 PM, M. Scot Breitenfeld
> > <brtnfld at uiuc.edu <mailto:brtnfld at uiuc.edu>
> > > <mailto:brtnfld at uiuc.edu <mailto:brtnfld at uiuc.edu>>> wrote:
> > > Hi,
> > > First, thanks for the suggestion on using MPISBAIJ for my A
> > matrix, it
> > > seems to have cut down on my memory and assembly time. For a
> 1.5
> > > million
> > > dof problem:
> > > # procs: 2 4 8 16
> > > Assembly (sec): 245 124 63 86
> > > Solver (sec): 924 578 326 680
> > > Memory (GB): 2.5 1.4 .877 .565
> > > The problem I have is the amount of time it's taking in
> > AOCreateBasic,
> > > it takes longer then assembling,
> > > # procs: 2 4 8
> > 16
> > > AOCreateBasic (sec): .6 347 170 197
> > > Is there something that I can change or something I can look
> > for that
> > > might be causing this increase in time as I go from 2 to 4
> > processors
> > > (at least it scales from 4 to 8 processors). I read in the
> > archive
> > > that
> > > AOCreateBasic is not meant to be scalable so maybe there is
> > nothing I
> > > can do.
> > > Yes, this is non-scalable. What are you using it for?
> > > Matt
> > > Thanks,
> > > Scot
> > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to
> which
> > > their experiments lead.
> > > -- Norbert Wiener
> > experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110304/a67d5a21/attachment.htm>
