[petsc-users] AOCreateBasic is not scaling
M. Scot Breitenfeld
brtnfld at uiuc.edu
Fri Mar 4 15:14:38 CST 2011
On 03/03/2011 12:18 PM, Matthew Knepley wrote:
> On Wed, Mar 2, 2011 at 4:52 PM, M. Scot Breitenfeld <brtnfld at uiuc.edu
> <mailto:brtnfld at uiuc.edu>> wrote:
> I don't number my global degree's of freedom from low-high
> continuously
> per processor as PETSc uses for ordering, but I use the natural
> ordering
> of the application, I then use AOcreateBasic to obtain the mapping
> between the PETSc and my ordering.
> I would suggest using the LocalToGlobalMapping functions, which are
> scalable.
> AO is designed for complete global permutations.
I don't understand how I can avoid not using AO if my global dof per
processor are not arranged in PETSc global ordering (continuous row
ordering, i.e. proc1_ 0-n, proc2_n+1:m, proc3_m+1:p, etc...). In the
LocalToGlobalMapping routines, doesn't the "GlobalMapping" part mean
PETSc ordering and not my application's ordering.
I thought I understood the difference between AO and
LocalToGlobalMapping but now I'm confused. I tried to use the
LocalToGlobalMapping routines and the solution values are correct but
the ordering corresponds the global node ordering, not how I partitioned
the mesh. In other words, the values are returned in the same ordering
as for a serial run, which makes sense since this is how PETSc orders
the rows. If I had used PETSc ordering then this would be fine.
Is the moral of the story, if I want to get scalability I need to
rearrange my global dof in PETSc ordering so that I can use
LocalToGlobalMapping?
> Thanks,
> Matt
> CALL VecGetOwnershipRange(b, low, high, ierr)
> icnt = 0
> DO mi = 1, mctr ! these are the nodes local to processor
> mi_global = myglobal(mi)
> irowx = 3*mi_global-2
> irowy = 3*mi_global-1
> irowz = 3*mi_global
> mappings(icnt+1:icnt+3) = (/ &
> nrow_global(row_from_dof(1,mi))-1, &
> nrow_global(row_from_dof(2,mi))-1, &
> nrow_global(row_from_dof(3,mi))-1 &
> petscOrdering(icnt+1:icnt+3) =
> (/low+icnt,low+icnt+1,low+icnt+2/)
> icnt = icnt + 3
> END DO
> CALL AOCreateBasic(PETSC_COMM_WORLD, icnt, mappings, petscOrdering,
> toao, ierr)
> DO mi = mctr+1, myn ! these are the ghost nodes not on this processor
> icnt = icnt + 3
> ENDDO
> CALL AOApplicationToPetsc(toao, 3*myn, mappings, ierr)
> CALL AODestroy(toao, ierr)
> I then use mapping to input the values into the correct row as wanted
> by PETSc
> On 03/02/2011 04:29 PM, Matthew Knepley wrote:
> > On Wed, Mar 2, 2011 at 4:25 PM, M. Scot Breitenfeld
> <brtnfld at uiuc.edu <mailto:brtnfld at uiuc.edu>
> > <mailto:brtnfld at uiuc.edu <mailto:brtnfld at uiuc.edu>>> wrote:
> > Hi,
> > First, thanks for the suggestion on using MPISBAIJ for my A
> matrix, it
> > seems to have cut down on my memory and assembly time. For a 1.5
> > million
> > dof problem:
> > # procs: 2 4 8 16
> > Assembly (sec): 245 124 63 86
> > Solver (sec): 924 578 326 680
> > Memory (GB): 2.5 1.4 .877 .565
> > The problem I have is the amount of time it's taking in
> AOCreateBasic,
> > it takes longer then assembling,
> > # procs: 2 4 8
> 16
> > AOCreateBasic (sec): .6 347 170 197
> > Is there something that I can change or something I can look
> for that
> > might be causing this increase in time as I go from 2 to 4
> processors
> > (at least it scales from 4 to 8 processors). I read in the
> archive
> > that
> > AOCreateBasic is not meant to be scalable so maybe there is
> nothing I
> > can do.
> > Yes, this is non-scalable. What are you using it for?
> > Matt
> > Thanks,
> > Scot
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
> -- Norbert Wiener
