[petsc-users] PCCOMPOSITE and ApplyTranspose
Jed Brown jed at 59A2.org
Thu Jun 23 04:29:32 CDT 2011
On Thu, Jun 23, 2011 at 11:13, Andrew T Barker
<Andrew.Barker at colorado.edu>wrote:
> I've made a PCCOMPOSITE that contains two PCSHELLS, both of
> which have a transpose set with PCShellSetApplyTranspose().
> However the composite PC does not seem to support the
> transpose:
Yeah, PCApplyTranspose_Composite() has not been implemented. Are you using
additive or multiplicative? Could you explain what the preconditioner is?
(It's possible that there is a different way to do it that would have a
nicer interface, for example, using PCFIELDSPLIT).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110623/ed891675/attachment.htm>
