[petsc-users] PCCOMPOSITE and ApplyTranspose
Fri Jun 24 22:22:04 CDT 2011
  I have added PCApplyTranspose() for PCCOMPOSITE in petsc-dev. You will need to switch to petsc-dev http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html to access it.
   Sorry for the inconvenience.
   Barry
On Jun 23, 2011, at 4:13 AM, Andrew T Barker wrote:
> I've made a PCCOMPOSITE that contains two PCSHELLS, both of
> which have a transpose set with PCShellSetApplyTranspose().
> However the composite PC does not seem to support the
> transpose:
> [0]PETSC ERROR: No support for this operation for this object
> type!
> [0]PETSC ERROR: PC does not have apply transpose!
> The code runs fine with the composite replaced with either of
> the shells by itself.  Of course I can implement my own
> composite as a PCShell with a transpose easily enough, but I
> was wondering if this was expected or if I am making some
> other mistake.
> I am using Petsc 3.0.0.
> Thanks,
> Andrew
