[petsc-users] long int
    Mohammad Mirzadeh
    mirzadeh at gmail.com
    Sun Jun 12 13:35:53 CDT 2011
Sorry for misspells . It's my phone's auto correct!
On Jun 12, 2011 11:33 AM, "Mohammad Mirzadeh" <mirzadeh at gmail.com> wrote:
> Thanks Barry. Problem is my indices are all long and if I use the with
petsc
> the compiler will complain. Do you think casting them to int will solve
the
> problem? Also how does 64 bit international affect petsc performance?
> Thanks
> On Jun 12, 2011 9:39 AM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
>> On Jun 12, 2011, at 1:48 AM, Mohammad Mirzadeh wrote:
>>> I guess I figured it out. On 64-bit OS long long and long are the same
> and I may as well just use --with-64-bit-ints flag.
>> You only need to configure PETSc with --with-64-bit-indices if you are
> dealing with problems with over 2 billion unknowns (in parallel) or if the
> sparse matrix will have more than 2 billion nonzeros on a single process.
> You do not need to use --with-64-bit-indices just because you are using 64
> bit pointers, only for really large problems.
>> Barry
>>> Thanks
>>> On Sat, Jun 11, 2011 at 11:22 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>
> wrote:
>>> Hi guys,
>>> How can I use long int instead of PetscInt in the functions? Does simply
> changing the definition of PetscInt solve the problem?
>>> Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110612/04e80ee9/attachment.htm>
