[petsc-users] PETSc, C++ and Eclipse
Matt Bockman
mdbockma at ucsd.edu
Wed Jul 27 21:22:56 CDT 2011
Nevermind, I was completely wrong. I actually was able to build it using the
commands that the original makefile produced (from PETSc), then when I went
into Eclipse I forgot to press "clean"...derr.
Matt
On Wed, Jul 27, 2011 at 7:21 PM, Matt Bockman <mdbockma at ucsd.edu> wrote:
> Hi Berend,
> First of all, you have been extremely helpful. Second, I was FINALLY able
> to compile the example through Eclipse. Sadly, it's the biggest breakthrough
> I've had in the last 2 weeks of my research :(.
> Here's what I did:
> I tried running what Eclipse was running from a terminal:
> Eclipse:
> /home/mdbockman/Documents/Research/codes/petsc/petsc-3.1-p8/linux-gnu-c-debug/bin/mpicc
> -I/home/mdbockman/Documents/Research/codes/petsc/petsc-3.1-p8/linux-gnu-c-debug/include
> -I/home/mdbockman/Documents/Research/codes/petsc/petsc-3.1-p8/include -O0
> -g3 -Wall -Wwrite-strings -Wno-strict-aliasing -MMD -MP -MF"ex1.d"
> -MT"ex1.d" -o"ex1.o" "../ex1.c"
> That did not work. So I ran make ex1 in the original ex1 tutorial directory
> and saw what the makefile was doing there:
> -o ex1.o -c -Wall -Wwrite-strings -Wno-strict-aliasing -g3
> -I/home/mdbockman/Documents/Research/codes/petsc/petsc-3.1-p8/src/dm/mesh/sieve
> -D__INSDIR__=src/ksp/ksp/examples/tutorials/ ex1.c
> -Wall -Wwrite-strings -Wno-strict-aliasing -g3 -o ex1 ex1.o
> -Wl,-rpath,/home/mdbockman/Documents/Research/codes/petsc/petsc-3.1-p8/linux-gnu-c-debug/lib
> -L/home/mdbockman/Documents/Research/codes/petsc/petsc-3.1-p8/linux-gnu-c-debug/lib
> -lpetsc -lX11
> -lflapack -lfblas -lnsl -lrt -lm
> -L/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2
> -L/usr/lib/x86_64-linux-gnu -ldl -lmpich -lpthread -lrt -lgcc_s -lmpichf90
> -lgfortran -lm -lm -ldl -lmpich -lpthread -lrt -lgcc_s -ldl
> So apparently it was making an object file then linking. I then compared
> the one from Eclipse and found that I was missing
> -I/home/mdbockman/Documents/Research/codes/petsc/petsc-3.1-p8/src/dm/mesh/sieve.
> Why I need this I do not know (ideas?).
> But, after I found that I added it to my Include Directories and it
> compiled!
> Thanks Berend and others, I appreciate your persistence and aid.
> Matt
> On Wed, Jul 27, 2011 at 6:28 PM, Berend van Wachem <
> b.van-wachem at imperial.ac.uk> wrote:
>> Dear Matt,
>> I can't directly see anything wrong with your settings.
>> Have you tried compiling your example outside of eclipse with the PETSc
>> makefile system?
>> The previous pastebin output you emailed me does suggest that the error is
>> during the compile stage: it cannot find the correct headers describing the
>> implementations of PetscInitialize etc.
>> Have you tried using the mpicc outside of eclipse directly on the
>> directory?
>> /home/mdbockman/Documents/**Research/codes/petsc/petsc-3.**
>> 1-p8/linux-gnu-c-debug/bin/**mpicc -I"/home/mdbockman/Documents/**
>> Research/codes/petsc/petsc-3.**1-p8/include"
>> -I"/home/mdbockman/Documents/**Research/codes/petsc/petsc-3.**
>> 1-p8/linux-gnu-c-debug/**include" -O0 -g3 -Wall -Wwrite-strings
>> -Wno-strict-aliasing -MMD -MP -MF"ex1.d" -MT"ex1.d" -o"ex1.o" "../ex1.c"
>> within the eclipse directory? This way you can more easily play around
>> with it to see what is the problem.
>> I'm sorry I can't be of more help.
>> Regards,
>> Berend.
>> On 07/28/2011 02:20 AM, Matt Bockman wrote:
>>> Hi Berend,
>>> Under Library search path I have:
>>> For libraries I have:
>>> petsc
>>> X11
>>> flapack
>>> fblas
>>> nsl
>>> rt
>>> m
>>> dl
>>> mpich
>>> pthread
>>> rt
>>> gcc_s
>>> mpichf90
>>> gfortran
>>> m
>>> m
>>> dl
>>> mpich
>>> rt
>>> gcc_s
>>> dl
>>> I used the exact order as I found in petscmachineinfo.h file (see here:
>>> http://pastebin.com/cqzNgjJe)
>>> Thank you very much for your help Berend,
>>> Matt
>>> On Wed, Jul 27, 2011 at 6:11 PM, Berend van Wachem
>>> <b.van-wachem at imperial.ac.uk <mailto:b.van-wachem at imperial.**ac.uk<b.van-wachem at imperial.ac.uk>>>
>>> wrote:
>>> Dear Matt,
>>> What do you have under
>>> Properties->C/C++ Build -> Settings -> GCC Linker Libraries for both
>>> "Libraries" and "Library Search Path"?
>>> Regards,
>>> Berend.
>>> On 07/28/2011 02:04 AM, Matt Bockman wrote:
>>> Hi Berend,
>>> Under Properties->C/C++ Build -> Settings -> GCC C Compiler ->
>>> Directories : Include paths (-I) I have:
>>> /home/mdbockman/Documents/__**Research/codes/petsc/petsc-3._**
>>> _1-p8/include
>>> _1-p8/linux-gnu-c-debug/**include
>>> Under Properties -> C/C++ BUild -> Environment -> I have
>>> PETSC_ARCH = linux-gnu-c-debug
>>> PETSC_DIR =
>>> _1-p8
>>> In my source file I have included petsc.h:
>>> #include "petsc.h"
>>> Thanks,
>>> Matt
>>> On Wed, Jul 27, 2011 at 5:54 PM, Berend van Wachem
>>> <mailto:b.van-wachem at imperial.**__ac.uk
>>> <mailto:b.van-wachem at imperial.**ac.uk<b.van-wachem at imperial.ac.uk>>>>
>>> wrote:
>>> Dear Matt,
>>> The error is definitely in the compiler stage: it cannot find that
>>> appropriate petsc.h include file.
>>> 1. Have you included petsc.h in the source file?
>>> 2. What do you have under
>>> <Your Project> -> Settings -> Includes
>>> Also, just to make sure, you can set the appropriate values for
>>> PETSC_DIR and PETSC_ARCH if you wish under
>>> <Your Project> -> Settings -> Environment
>>> Regards,
>>> Berend.
>>> On 07/28/2011 01:49 AM, Matt Bockman wrote:
>>> Hi Berend,
>>> Here is the complete output of the build:
>>> http//pastebin.com/Es4ms4EF <http://pastebin.com/Es4ms4EF>
>>> and by the 2nd to last line "collect2: ld returned 1 exit status"
>>> I
>>> believe it is failing during the linking step. I'm not 100% sure
>>> though.
>>> Thanks for your quick response and help. Please advise,
>>> Matt
>>> On Wed, Jul 27, 2011 at 5:39 PM, Berend van Wachem
>>> ac.uk <b.van-wachem at imperial.ac.uk>>
>>> <mailto:b.van-wachem at imperial.**>____ac.uk <http://ac.uk>
>>> <mailto:b.van-wachem at imperial.**ac.uk<b.van-wachem at imperial.ac.uk>>>>>
>>> wrote:
>>> Dear Matt,
>>> Does it say this during the compiling? Or linking?
>>> If it says this during the compiling, it means that eclipse cannot
>>> find the PETSc header files. So, it must be the setting of the
>>> "Includes". You might want to "hard-code" the directory, just to
>>> make sure.
>>> It is indeed not completely straightforward - eclipse has so many
>>> options. But trust me - many of them you will really learn to
>>> appreciate over time.
>>> Kind regards,
>>> Berend.
>>> On 07/28/2011 01:34 AM, Matt Bockman wrote:
>>> Thanks Berend for your thorough response,
>>> I have done what you have said but I still get the same error
>>> regarding
>>> "undefined references to PetscInitialize" etc. It's like I didn't
>>> include the petscksp.h file, but it's there. I even tried
>>> petsc.h to no
>>> avail.
>>> I'm not sure what the compiler is referring to when it says
>>> "Undefined
>>> references to ...". What I think this is is in the assembly code
>>> generated by the compiler, there is a PetscInitialize symbol
>>> that isn't
>>> found in the library. But I'm soooooooooo confused at this point
>>> :(. How
>>> did you guys all learn how to compile this?
>>> Matt
>>> On Wed, Jul 27, 2011 at 4:46 PM, Berend van Wachem
>>> <mailto:b.van-wachem at imperial <mailto:b.van-wachem at imperial>**.
>>> <mailto:b.van-wachem at imperial>**.__>____ac.uk <http://ac.uk>
>>> <http://ac.uk>
>>> <mailto:b.van-wachem at imperial.**ac.uk<b.van-wachem at imperial.ac.uk>>>>>>
>>> wrote:
>>> Dear Matt,
>>> I use Eclipse and have eclipse make the makefiles.
>>> It is just a matter of indicating to eclipse where the PETSc
>>> headers/libraries are to be found, so if you have a C project
>>> which
>>> needs PETSc headers and libraries:
>>> To do this, click on your managed C project with the right sided
>>> mouse button, select
>>> Properties -> C/C++ Build -> Settings
>>> Then you get a new window with on the right hand side the various
>>> setting options.
>>> Select Includes, and add the required PETSc paths. In my case I
>>> have
>>> added
>>> ${PETSC_DIR}/include
>>> ${PETSC_DIR}/${PETSC_ARCH}/___**_____include
>>> Then select "Libraries" under the header Linker
>>> and you should set the Library search path:
>>> ${PETSC_DIR}/${PETSC_ARCH}/lib
>>> and then the libraries, in my case:
>>> m, petsc, stdc++, mpichxx, mpich, lapack, blas, gfortran, dl,
>>> rt,gcc_s, pthread, X11
>>> (you can find these easily in
>>> $PETSC_DIR/$PETSC_ARCH/_______**_petscmachineinfo.h)
>>> The nice thing is that in eclipse you can easily switch between
>>> Debug/Release code, traverse into the PETSc source code etc. It's
>>> really a very productive tool with PETSc I've found.
>>> Let me know if you have any questions.
>>> Kind regards,
>>> Berend.
>>> On 07/27/2011 11:25 PM, Matt Bockman wrote:
>>> Thanks everyone for the help,
>>> I was able to compile a single example in Eclipse using the
>>> provided
>>> makefile. I'm pretty new to makefiles so it's a LOT to digest.
>>> I'm now
>>> manually creating a makefile for my project in Eclipse (and I've
>>> set
>>> Eclipse up to use a makefile that I create instead of
>>> automatically
>>> generating one). Unfortunately this is a big pain but since I
>>> can't
>>> figure out how to make Eclipse automatically include a few files
>>> in the
>>> makefile I don't really have any other choices :(.
>>> Thanks again,
>>> Matt
>>> On Wed, Jul 27, 2011 at 1:43 PM, Mohammad Mirzadeh
>>> <mirzadeh at gmail.com <mailto:mirzadeh at gmail.com>
>>> <mailto:mirzadeh at gmail.com <mailto:mirzadeh at gmail.com>>
>>> <mailto:mirzadeh at gmail.com <mailto:mirzadeh at gmail.com>>>
>>> <mailto:mirzadeh at gmail.com <mailto:mirzadeh at gmail.com>>>>
>>> <mailto:mirzadeh at gmail.com <mailto:mirzadeh at gmail.com>>>>**>__>
>>> wrote:
>>> There two problems(I think) in this code.
>>> 1) there is no main function in your source code. If this is the
>>> only file you are compiling, you need to change the function name
>>> to
>>> main.
>>> 2) linking should be done after object files are created. A simple
>>> g++ call would first compile the main file and then link the
>>> object
>>> to the petsc lib i.e
>>> g++ -c -I($PETSC_INCLUDE) main.cpp
>>> g++ -o main main.o $PETSC_LIBS
>>> alternatively, you could do it in a single line if you like
>>> g++ -o main -I($PETSC_INCLUDE) main.cpp $PETSC_LIBS
>>> my point is you should link to petsc after compiling your own
>>> code.
>>> So wherever in Eclipse that you are seting the parameters, make
>>> sure
>>> the $PETSC_LIBS is in the linker option and not compiler.
>>> Mohammad
>>> On Wed, Jul 27, 2011 at 12:39 PM, Matt Bockman
>>> <mdbockma at ucsd.edu <mailto:mdbockma at ucsd.edu>
>>> <mailto:mdbockma at ucsd.edu <mailto:mdbockma at ucsd.edu>>
>>> <mailto:mdbockma at ucsd.edu <mailto:mdbockma at ucsd.edu>>>
>>> <mailto:mdbockma at ucsd.edu <mailto:mdbockma at ucsd.edu>>>>
>>> <mailto:mdbockma at ucsd.edu <mailto:mdbockma at ucsd.edu>>>>>**>
>>> wrote:
>>> I added the include directories from "make getincludedirs" and I
>>> added the line from "make getlinklib". Eclipse creates a gcc
>>> call as follows:
>>> /home/mdbockman/Documents/____**____Research/codes/petsc/**
>>> petsc-__3.______1-p8/linux-**gnu-c-__debug/bin/______mpicc
>>> -I/home/mdbockman/Documents/__**______Research/codes/petsc/__**
>>> petsc-__3.____1-p8/linux-gnu-_**_c-debug/____include
>>> petsc-__3.____1-p8/include
>>> -O0 -g3 -pg -p -Wall
>>> -Wl,-rpath,/home/mdbockman/___**_____Documents/Research/codes/**
>>> ________petsc/petsc-3.1-p8/**linux-__gnu-______c-debug/lib
>>> -L/home/mdbockman/Documents/__**______Research/codes/petsc/__**
>>> petsc-__3.____1-p8/linux-gnu-_**_c-debug/__lib
>>> -lpetsc -lX11
>>> -L/usr/lib/x86_64-linux-gnu/__**______gcc/x86_64-linux-gnu/4.**
>>> 5.2
>>> -lmpichf90 -lgfortran -lm -lm -ldl -lmpich -lpthread -lrt
>>> -lgcc_s -ldl -MMD -MP -MF"SparseMatrixPetsc.d"
>>> -MT"SparseMatrixPetsc.d" -o"SparseMatrixPetsc.o"
>>> "../SparseMatrixPetsc.c
>>> And when it is compiled I get the following:
>>> http://pastebin.com/CbRzYcZj
>>> The source file which is being compiled is:
>>> http://pastebin.com/Q85hXvnS
>>> Please have a look. I'm not quite sure what I'm doing wrong but
>>> I feel like I'm getting closer and closer to the solution.
>>> Matt
>>> On Wed, Jul 27, 2011 at 11:52 AM, Satish Balay
>>> <balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>
>>> <mailto:balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>>
>>> <mailto:balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>>>
>>> <mailto:balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>>>>
>>> <mailto:balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>>>>>**>
>>> wrote:
>>> use:
>>> make getincludedirs
>>> Satish
>>> On Wed, 27 Jul 2011, Mohammad Mirzadeh wrote:
>>> > I applogize for the mistake; Include files are actually
>>> located
>>> > in $PETSC_DIR/include
>>> > On Wed, Jul 27, 2011 at 11:18 AM, Mohammad Mirzadeh
>>> <mailto:mirzadeh at gmail.com>>>>**>__>______wrote:
>>> > > Ok then. Now I don't have enough experience with Eclipse so
>>> > > I apologize beforehand if you already know these/have
>>> tried them out. If
>>> > > not, hopefully they can be of help. I assume there
>>> should be a way in
>>> > > Eclipse to give it the link lib directory. In plain
>>> makefile that's just a
>>> > > simple step when linking. To get all the needed
>>> linklibs for petsc, you can
>>> > > do
>>> > > make getlinklibs
>>> > > in the $PETSC_DIR. As for the needed include files,
>>> they are all located
>>> > > in
>>> > > $PETSC_DIR/$PETSC_ARCH/include
>>> > > Again, its easy to use these directories along with
>>> your makefile. I'm not
>>> > > sure about how you give them to Eclipse though.
>>> Hopefully this has been
>>> > > helpful.
>>> > > Best,
>>> > > Mohammad
>>> > > On Wed, Jul 27, 2011 at 10:52 AM, Matt Bockman
>>> wrote:
>>> > >> Just pointing it to the library would be sufficient.
>>> > >> Matt
>>> > >> On Wed, Jul 27, 2011 at 10:21 AM, Mohammad Mirzadeh
>>> > >>> So do you want to be able to compile PETSc with
>>> Eclipse or just point it
>>> > >>> to the library to use in your own applications?
>>> > >>> On Wed, Jul 27, 2011 at 9:14 AM, Matt Bockman
>>> wrote:
>>> > >>>> Thanks Mohammad,
>>> > >>>> I'll give that a shot. I use Qt Creator for some GUI
>>> applications so I
>>> > >>>> am familiar with it, but I've never tried doing a
>>> non-Qt project in it. I'd
>>> > >>>> really like to get Eclipse to work.
>>> > >>>> Regarding the makefiles for eclipse. There are
>>> makefiles that it
>>> > >>>> generates (which are for GNU make) but I think I can
>>> also manually create my
>>> > >>>> makefiles. After sleeping on it, it seems like this
>>> might be the best
>>> > >>>> option, unless I can figure out a way to configure
>>> eclipse to include the
>>> > >>>> conf/variables and conf/rules files in the makefile.
>>> > >>>> Matt
>>> > >>>> On Wed, Jul 27, 2011 at 12:01 AM, Mohammad Mirzadeh
>>> > >>>> > wrote:
>>> > >>>>> Although this is sort of orthogonal to what you do
>>> right now,
>>> > >>>>> I recommend Qt Creator as an alternative IDE to
>>> Eclipse. It links nicely
>>> > >>>>> with PETSc(or any other library for that matter)
>>> and has excellent c/c++
>>> > >>>>> support.
>>> > >>>>> Mohammad
>>> > >>>>> On Tue, Jul 26, 2011 at 7:22 PM, Barry Smith
>>> <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>
>>> <mailto:bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
>>> <mailto:bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>>
>>> <mailto:bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>>>
>>> <mailto:bsmith at mcs.anl.gov>>>>**>__>______wrote:
>>> > >>>>>> There is a tiny bit of information in the PETSc
>>> users manual about
>>> > >>>>>> Eclipse:
>>> > >>>>>> \section{Eclipse Users} \sindex{eclipse}
>>> > >>>>>> If you are interested in developing code that uses
>>> PETSc from Eclipse
>>> > >>>>>> or developing PETSc in Eclipse and have knowledge
>>> of how to do indexing and
>>> > >>>>>> build libraries in Eclipse please contact us at \
>>> > >>>>>> trl{petsc-dev at mcs.anl.gov
>>> <mailto:trl%7Bpetsc-dev at mcs.**anl.gov<trl%257Bpetsc-dev at mcs.anl.gov>
>>> <mailto:trl%7Bpetsc-dev at mcs.__**anl.gov <http://anl.gov>
>>> <mailto:trl%257Bpetsc-dev at mcs.**anl.gov<trl%25257Bpetsc-dev at mcs.anl.gov>
>>> <mailto:trl%257Bpetsc-dev at mcs.**>____anl.gov <http://anl.gov>
>>> <mailto:trl%257Bpetsc-dev at mcs.**__anl.gov
>>> <mailto:trl%25257Bpetsc-dev@**mcs.anl.gov<trl%2525257Bpetsc-dev at mcs.anl.gov>
>>> <mailto:trl%7Bpetsc-dev at mcs <mailto:trl%257Bpetsc-dev at mcs>**.
>>> <mailto:trl%25257Bpetsc-dev@**mcs <trl%2525257Bpetsc-dev at mcs>
>>> >.__>____anl.gov <http://anl.gov>
>>> <http://anl.gov>
>>> .>____anl.gov <http://anl.gov>
>>> <mailto:trl%25257Bpetsc-dev at __**mcs.anl.gov <http://mcs.anl.gov>
>>> <mailto:trl%2525257Bpetsc-dev@**mcs.anl.gov<trl%252525257Bpetsc-dev at mcs.anl.gov>
>>> <mailto:trl%257Bpetsc-dev at mcs <mailto:trl%25257Bpetsc-dev@**mcs<trl%2525257Bpetsc-dev at mcs>
>>> >>__.
>>> <mailto:trl%2525257Bpetsc-dev@**mcs <trl%252525257Bpetsc-dev at mcs>
>>> >>.__>____anl.gov
>>> <http://anl.gov> <http://anl.gov>
>>> <http://anl.gov>
>>> <http://anl.gov>
>>> <mailto:trl%2525257Bpetsc-dev@**>____mcs.anl.gov <
>>> http://mcs.anl.gov>
>>> <mailto:trl%2525257Bpetsc-dev@**__mcs.anl.gov
>>> <mailto:trl%252525257Bpetsc-**dev at mcs.anl.gov<trl%25252525257Bpetsc-dev at mcs.anl.gov>
>>> > >>>>>> To make PETSc an Eclipse package
>>> > >>>>>> \begin{itemize}
>>> > >>>>>> \item Install the Mecurial plugin for Eclipse and
>>> then import the
>>> > >>>>>> PETSc repository to Eclipse.
>>> > >>>>>> \item elected New->Convert to C/C++ project and
>>> selected shared
>>> > >>>>>> library. After this point you can perform searchs
>>> in the code.
>>> > >>>>>> \end{itemize}
>>> > >>>>>> A PETSc user has provided the following steps to
>>> build an Eclipse
>>> > >>>>>> index for PETSc that can be used with their own
>>> code without compiling PETSc
>>> > >>>>>> source into their project.
>>> > >>>>>> \begin{itemize}
>>> > >>>>>> \item In the user project source directory, create
>>> a symlink to the
>>> > >>>>>> petsc/src directory.
>>> > >>>>>> \item Refresh the project explorer in Eclipse, so
>>> the new symlink is
>>> > >>>>>> followed.
>>> > >>>>>> \item Right-click on the project in the project
>>> explorer, and choose
>>> > >>>>>> "Index -> Rebuild". The index should now be build.
>>> > >>>>>> \item Right-click on the PETSc symlink in the
>>> project explorer, and
>>> > >>>>>> choose "Exclude from build..." to make sure
>>> Eclipse does not try to compile
>>> > >>>>>> PETSc with the project.
>>> > >>>>>> \end{itemize}
>>> > >>>>>> We'd love to have someone figure out how to do it
>>> right and include
>>> > >>>>>> that information.
>>> > >>>>>> Barry
>>> > >>>>>> On Jul 26, 2011, at 4:32 PM, Matt Bockman wrote:
>>> > >>>>>> > Has anyone gotten PETSc to work w/Eclipse?
>>> Eclipse nicely generates
>>> > >>>>>> all my makefiles for me for my current project
>>> (which is written in C++).
>>> > >>>>>> I'd like to link PETSc w/my application but I'm
>>> not sure how to do this.
>>> > >>>>>> > Suggestions?
>>> > >>>>>> > Thanks,
>>> > >>>>>> > Matt
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110727/da83d4b7/attachment-0001.htm>
