[petsc-users] superlu ILUT preconditioner break
    Gong Ding
    gdiso at ustc.edu
    Sun Jul 17 04:53:40 CDT 2011
BTW, this problem can be avoided by setting
-mat_superlu_rowperm to NOROWPERM instead of default value LargeDiag
> Several months ago, I posted message "superlu ILUT preconditioner break" with following link
> http://lists.mcs.anl.gov/pipermail/petsc-users/2011-March/008355.html
> Today I studied this problem carefully to see why it crashes.
> The segment fault is arising at line 692 of superlu's dgsisx.c, because the array "perm" is 0.
> This array which contains the permutation calculated from MC64 procedure, can only be initialized when nofact flag is true. However, petsc will call dgsisx twice, with nofact value 1 and 0, respectively.  In the second calling, the perm array is not initialized but be used. That's why the code crash.
> Hope this bug can be fixed without too many efforts.
> Gong Ding
