[petsc-users] PETSc recommended visualization packages
Ethan Coon ecoon at lanl.gov
Thu Jul 14 14:22:13 CDT 2011
Attached patch takes Lisandro's matio.py and puts it in a
PetscBinaryRead.py that reads a binary with (potentially) multiple Petsc
objects, deciphers the contents of the file from the header, and returns
numpy objects.  It's basically the same as the PetscBinaryRead.m
I've tested this on Vecs, but not Mats or ISs, and I haven't thoroughly
tested degenerate cases.  Will do some testing, but I wanted Lisandro to
take a look at it as well...
Ethan
On Wed, 2011-07-06 at 12:24 -0300, Lisandro Dalcin wrote:
> On 6 July 2011 11:41, Ethan Coon <ecoon at lanl.gov> wrote:
> > Both Paraview and Visit generally make ugly axes/colorbars/keys/etc.  In my opinion they both look fine for presentations and my own viewing, but are not really acceptable for publication-quality.  For things run on a reasonably-sized problem, matplotlib (using either h5py to read hdf5, pyvtk to read vtk, or petsc4py to read PETSc's binary format) makes publishable plots.
> Using petsc4py for reading PETSc binary formats is overkill. All this
> can be done with just NumPy. Should PETSc ship some Python code to
> read IS's, Vec's, Mat's in binary format? Can any of you suggest an
> appropriate location in the source tree?
Ethan Coon
Post-Doctoral Researcher
Applied Mathematics - T-5
Los Alamos National Laboratory
505-665-8289
http://www.ldeo.columbia.edu/~ecoon/
Type: text/x-python
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110714/e38a5560/attachment-0001.py>
