[petsc-users] Debugging hints welcome
Clemens Domanig
clemens.domanig at uibk.ac.at
Wed Jul 13 15:56:24 CDT 2011
I tried with -mat_no_inode - no effect. Thats the output
[1] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
[0] MatStashScatterBegin_Private(): No of messages: 1
[0] MatStashScatterBegin_Private(): Mesg_to: 1: size: 704692232
[0] MatAssemblyBegin_MPIAIJ(): Stash has 88086528 entries, uses 13 mallocs.
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 553824 X 553824; storage
space: 24984360 unneeded,19875384 used
[0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 42
Am 2011-07-13 22:10, schrieb Matthew Knepley:
> On Wed, Jul 13, 2011 at 4:08 PM, Clemens Domanig
> <clemens.domanig at uibk.ac.at <mailto:clemens.domanig at uibk.ac.at>> wrote:
> Hi everyone,
> maybe some can offer som debugging-hints for my problem.
> Its possible that there is a bug in the inode routines. Please try
> running with -mat_no_inode
> Thanks,
> Matt
> My FEM-program uses a shell-element that has depending on the
> geometry 5 or 6 dof per node.
> The program uses MPI for parallel solving (LU, mumps).
> It works fine with all examples that have onyl 5 dof per node and
> that have a mixture of 5 and 6 dof per node.
> When doing examples that have 6 dof per node this happens:
> * when using more than 2 MPI processes everything seems to be fine.
> * when using 1 or 2 MPI processes MatAssemblyBegin() never finishes
> This is the last output of -info, -mat_view_info, -vec_view_info
> (with 2 MPI processes, matrix size 1107648x1107648)
> [0] MatStashScatterBegin_Private()__: No of messages: 1
> [0] MatStashScatterBegin_Private()__: Mesg_to: 1: size: 704692232
> mallocs.
> is 0
> [0] Mat_CheckInode(): Found 184608 nodes of 553824. Limit used: 5.
> Using Inode routines
> Thx for your help - respectfully C. Domanig
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
