[petsc-users] Debugging hints welcome
Wed Jul 13 15:10:57 CDT 2011
On Wed, Jul 13, 2011 at 4:08 PM, Clemens Domanig <clemens.domanig at uibk.ac.at
> wrote:
> Hi everyone,
> maybe some can offer som debugging-hints for my problem.
Its possible that there is a bug in the inode routines. Please try running
with -mat_no_inode
     Matt
> My FEM-program uses a shell-element that has depending on the geometry 5 or
> 6 dof per node.
> The program uses MPI for parallel solving (LU, mumps).
> It works fine with all examples that have onyl 5 dof per node and that have
> a mixture of 5 and 6 dof per node.
> When doing examples that have 6 dof per node this happens:
> * when using more than 2 MPI processes everything seems to be fine.
> * when using 1 or 2 MPI processes MatAssemblyBegin() never finishes
> This is the last output of -info, -mat_view_info, -vec_view_info (with 2
> MPI processes, matrix size 1107648x1107648)
> [1] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> [0] MatStashScatterBegin_Private()**: No of messages: 1
> [0] MatStashScatterBegin_Private()**: Mesg_to: 1: size: 704692232
> [0] MatAssemblyBegin_MPIAIJ(): Stash has 88086528 entries, uses 13 mallocs.
> [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 553824 X 553824; storage space:
> 24984360 unneeded,19875384 used
> [0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
> [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 42
> [0] Mat_CheckInode(): Found 184608 nodes of 553824. Limit used: 5. Using
> Inode routines
> Thx for your help - respectfully C. Domanig
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110713/e5768c97/attachment.htm>
