[petsc-users] Petsc has generated inconsistent data - Divide by zero!
Jed Brown
jedbrown at mcs.anl.gov
Sat Jul 9 17:51:16 CDT 2011
On Sat, Jul 9, 2011 at 17:43, TAY wee-beng <zonexo at gmail.com> wrote:
> Sorry about that. I just run interactively to get the output.
> Now I issued :
> mpiexec -np 1 ./a.out -ksp_type gmres -ksp_gmres_restart 1000
> -ksp_gmres_modifiedgramschmidt -ksp_monitor_true_residual -ksp_view -pc_type
> asm -sub_pc_type lu > log1
Your matrix is singular which implies a bug in your assembly code, probably
in the way you impose boundary conditions. Switch to a very small problem
size (e.g. 4 cells) and debug it until the matrix is correct and
non-singular.
You should also check the error codes so the code doesn't try to keep going
after a fatal error.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110709/98579536/attachment.htm>
