[petsc-users] Petsc has generated inconsistent data - Divide by zero!
TAY wee-beng zonexo at gmail.com
Sat Jul 9 17:43:58 CDT 2011
Sorry about that. I just run interactively to get the output.
Now I issued :
mpiexec -np 1 ./a.out  -ksp_type gmres -ksp_gmres_restart 1000
-ksp_gmres_modifiedgramschmidt -ksp_monitor_true_residual -ksp_view
-pc_type asm -sub_pc_type lu > log1
Same for the fgmres. Hope it's ok now.
Thanks!
Yours sincerely,
TAY wee-beng
On 10/7/2011 12:26 AM, Matthew Knepley wrote:
> 2011/7/9 TAY wee-beng <zonexo at gmail.com <mailto:zonexo at gmail.com>>
>     Hi Jed,
>     I have attached the output runing under linux. It's only running
>     with 1 processor. I am using runge kutta 3rd order to solve my
>     problem, so there's 3 substeps per time step ie I need to solve
>     the x/y momentum eqns 3 times per time step.
> 1) As Jed said, you have repeated output. Something is wrong with your
> MPI setup. I suspect you are using
>     the wrong mpiexec. Please do not send parallel results until your
> serial results work.
> 2) Always run with -ksp_view when you send results
> 3) You did not try using LU as Jed suggested.
>    Matt
>     The error occurs at t=2, substep=2. It stated in the output.
>     Btw, I am solving the x and y momentum eqns separately, since they
>     are independent of one another. How can I solve it together?
>     My code is:
>     call
>     MatSetValues(A_semi_x,1,II,1,JJ,semi_mat_x(k,kk),INSERT_VALUES,ierr)
>     call MatAssemblyBegin(A_semi_x,MAT_FINAL_ASSEMBLY,ierr)
>     call MatAssemblyEnd(A_semi_x,MAT_FINAL_ASSEMBLY,ierr)
>     call KSPGetPC(ksp_semi_x,pc_semi_x,ierr)
>     ksptype=KSPBCGS
>     call KSPSetType(ksp_semi_x,ksptype,ierr)
>     call KSPSetFromOptions(ksp_semi_x,ierr)
>     tol=1.e-5
>     call
>     KSPSetTolerances(ksp_semi_x,tol,PETSC_DEFAULT_DOUBLE_PRECISION,PETSC_DEFAULT_DOUBLE_PRECISION,PETSC_DEFAULT_INTEGER,ierr)
>     exactly the same for y...
>     call VecAssemblyBegin(b_rhs_semi_x,ierr)
>     call VecAssemblyEnd(b_rhs_semi_x,ierr)
>     call VecAssemblyBegin(xx_semi_x,ierr)
>     call VecAssemblyEnd(xx_semi_x,ierr)
>     call
>     KSPSetOperators(ksp_semi_x,A_semi_x,A_semi_x,SAME_NONZERO_PATTERN,ierr)
>     call KSPSolve(ksp_semi_x,b_rhs_semi_x,xx_semi_x,ierr)
>     call KSPGetConvergedReason(ksp_semi_x,reason,ierr)
>     Thanks alot!
>     Yours sincerely,
>     TAY wee-beng
>     On 9/7/2011 12:26 AM, Jed Brown wrote:
>>     On Fri, Jul 8, 2011 at 17:17, TAY wee-beng <zonexo at gmail.com
>>     <mailto:zonexo at gmail.com>> wrote:
>>         Hi Jed,
>>         This is my output when the error happens for gmres:
>>           2 KSP preconditioned resid norm 1.556688898463e+007 true
>>         resid norm 2.58995443
>>         8801e+003 ||Ae||/||Ax|| 1.232088736212e+003
>>           3 KSP preconditioned resid norm 1.207952812560e+003 true
>>         resid norm 9.05939430
>>         1179e+003 ||Ae||/||Ax|| 4.309719703237e+003
>>         1179e+003 ||Ae||/||Ax|| 4.309719703237e+003 3 KSP
>>         preconditioned resid norm 1.207952812560e+003 true resid norm
>>         9.05939430
>>           4 KSP preconditioned resid norm 3.815055004710e+001 true
>>         resid norm 1.96385966
>>         1729e+002 ||Ae||/||Ax|| 9.342439899591e+001
>>     Why is the same line output multiple times? Do you have an MPI
>>     problem?
>>     This convergence looks funky; I suspect your preconditioner is
>>     singular and/or nonlinear. Please send -ksp_view output as you
>>     are running here and with -pc_type asm -sub_pc_type lu.
>>         for fgmres:
>>          34 KSP preconditioned resid norm 2.428114102327e-005 true
>>         resid norm 3.35941610
>>         6265e-005 ||Ae||/||Ax|| 1.598129588716e-005
>>          35 KSP preconditioned resid norm 2.200715659545e-005 true
>>         resid norm 3.88294769
>>         5703e-005 ||Ae||/||Ax|| 1.847182191086e-005
>>          36 KSP preconditioned resid norm 2.011575409369e-005 true
>>         resid norm 3.89282805
>>         6204e-005 ||Ae||/||Ax|| 1.851882441357e-005
>>         Btw, I am solving the x and y momentum eqns so there 's 2
>>         eqns to solve.
>>     Do you solve them separately or both at once? (We usually
>>     recommend the latter.)
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110710/3cc13050/attachment-0001.htm>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110710/3cc13050/attachment-0002.diff>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110710/3cc13050/attachment-0003.diff>
