[petsc-users] scattering and communications
Matthew Knepley
knepley at gmail.com
Fri Jul 8 16:45:22 CDT 2011
On Fri, Jul 8, 2011 at 3:48 PM, Marco Cisternino <marco.cisternino at polito.it
> wrote:
> Thanks for the reply, Matt.
> I tried what you suggested, but I saw no inconsistency in the portion given
> to GP or extended_P.
> Moreover, I tried to see what happens giving no interface, i.e. a simple
> Laplace equation.
> In this case GP and extended_P have exactly the same structure and
> partitioning. And nothing changes.
> All the communications happens in VecScatterCreate, the actual scatter
> (begin and end) uses almost no time and no communications, but
> VecScatterCreate does.
> Could you explain me why?
VecScatterCreate() must find out what needs to be communicated, even if that
answer is nothing needs to be communicated.
Matt
> The two IS I use to create the scatter context are from sequential c
> vectors as large as the entire computational domain. Could be this the
> problem?
> If I used smaller and local vectors to create the ISs and then the scatter
> context, would VecScatterCreate be more performing??
> Thanks a lot.
> Marco
> On Thu, Jul 7, 2011 at 4:55 PM, Marco Cisternino<marco.cisternino@**
>> polito.it <marco.cisternino at polito.it>
>>> wrote:
>>> Hi,
>>> I would like to understand better how VecScatterBegin and VecScatterEnd
>>> work.
>>> I solve an interface elliptic problem on a Cartesian grid introducing
>>> extra
>>> unknowns (intersections between the interface and the grid axes).
>>> Therefore, my linear system is augmented with extra condition on these
>>> new
>>> unknowns.
>>> I use a DA to manage the grid, but I have to use MatCreateMPIAIJ to build
>>> the matrix because of the nature of the problem.
>>> MatCreateMPIAIJ(proc->cart_****comm,proc->intersections[proc-****
>>>> rank],proc->intersections[****proc->rank],g_rows,g_cols,21,****
>>> PETSC_NULL,21,PETSC_NULL,&****fsolv->AA);
>>> VecCreateMPI(proc->cart_comm,****proc->intersections[proc->**
>>> rank],PETSC_DECIDE,&fsolv->****extended_P);
>>> rank],PETSC_DECIDE,&fsolv->****extended_RHS);
>>> where
>>> proc->intersections[proc->****rank] is the total number of unknowns for
>>> each
>>> processor in its sub-domain (grid points + intersections).
>>> g_rows=g_cols is the total number of unknowns in the entire computational
>>> cart_comm is a Cartesian communicator.
>>> The arrangement of the unknowns is such that every processor has the rows
>>> of the matrix and of extended_P(the solution) relative to the actual
>>> unknowns in its sub-domain.
>>> I solve the system and then I call VecScatterBegin and VecScatterEnd:
>>> ierr=VecScatterCreate(fsolv->****extended_P,scatter->from,vec-**>**
>>> GP,scatter->to,&scatter->****scatt);
>>> ierr=VecScatterBegin(scatter->****scatt,fsolv->extended_P,vec-**>**
>>> GP,INSERT_VALUES,SCATTER_****FORWARD);
>>> ierr=VecScatterEnd(scatter->****scatt,fsolv->extended_P,vec->****
>>> in order to get in GP (made using DACreateGlobalVector(grid->da,**
>>> **&vec->GP);
>>> ) only the solution on the grid points.
>>> It works, I mean I can get the right solution in GP, but the scattering
>>> doesn't scale at all!
>>> I would expect no communications during the scattering, doing what I do,
>>> but -log_summary shows me a number of MPI message growing with the number
>>> of
>>> processors.
>>> Every portion of GP contains only the grid points of a processor, while
>>> every portion of extended_P contains the same grid points plus the
>>> intersections in the relative sub-domain. which is the need for the
>>> communications doing such a scattering?
>>> There is just a mismatch somewhere in your indices. It should be easy to
>> check the locally owned indices in
>> GP using
>> http://www.mcs.anl.gov/petsc/**petsc-as/snapshots/petsc-dev/**
>> docs/manualpages/Vec/**VecGetOwnershipRange.html<http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/docs/manualpages/Vec/VecGetOwnershipRange.html>
>> and compare to what you have.
>> Matt
>> I don't know if I was clear enough. Please, ask me what you need to
>>> understand my problem.
>>> Thanks a lot.
>>> Best regards,
>>> Marco
>>> Marco Cisternino
>>> PhD Student
>>> Politecnico di Torino
>>> Mobile:+393281189696
>>> Email:marco.cisternino at polito.****it<Email%3Amarco.cisternino@**
>>> polito.it <Email%253Amarco.cisternino at polito.it>>
> Marco Cisternino
> PhD Student
> Email:marco.cisternino at polito.**it <Email%3Amarco.cisternino at polito.it>
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110708/557b9b07/attachment.htm>
