[petsc-users] PETSc recommended visualization packages
Blaise A Bourdin
bourdin at lsu.edu
Thu Jul 7 15:01:14 CDT 2011
Brad,
Do you have examples of the way you encode mesh informations (connectivity table, block of elements, edges, vertices) in hdf5 files, and of the xdmf files that describe that layout? As I said in a previous message, I find the xdmf format documentation quite lacking.
I also use Sieve to represent my mesh.
Blaise
Sent from a handheld device.
On Jul 7, 2011, at 8:31 PM, Brad Aagaard <baagaard at usgs.gov> wrote:
> Ethan-
> I think writing an Xdmf file that points to the datasets in an HDF5 file is probably easier than creating a viewer. For PyLith we write the HDF5 file and a corresponding Xdmf file. This allows us to simply open the Xdmf file in ParaView; I think VisIt supports this as well.
> Brad
> On 07/07/2011 10:12 AM, Ethan Coon wrote:
>> The downside of this option is that, in order for hdf5 files to work in
>> anything but python (which is smart enough to use introspection on the
>> file itself) you need a special viewer (the VisIt people call this a
>> "flavor" of HDF5), see
>> http://visitusers.org/index.php?title=VisIt_and_HDF5
>> These work on both VisIt and Paraview, but I've never tried to write one
>> myself, so I don't know how ugly they are. They basically specify the
>> layout of the hdf5 file.
>> Note that if you go with the HDF5 option, you'll likely want to move to
>> petsc-dev, which includes more HDF5 functionality, such as groups.
