[petsc-users] Matrix Construction Question
Matthew Knepley
knepley at gmail.com
Thu Jul 7 13:09:34 CDT 2011
On Thu, Jul 7, 2011 at 5:02 PM, Adam Byrd <adam1.byrd at gmail.com> wrote:
> Changing the matrix types worked. When solving AX=B, X and B have to be
> dense and A can be a sparse format? I'd like to avoid storing the identity
> as a dense format, if possible. By the way, the man page for MATAIJ says
> it's a sparse format
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MATAIJ.html
Yes, AIJ is sparse.
> I must ask, is there somewhere in the documentation I should be looking to
> figure these sorts of questions out? I feel like a pest, but I'm not sure
> where else to look for answers.
Which questions? If you mean about the MatMatSolve, it says the arguments
must be dense on the webpage:
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatMatSolve.html
There is also a manual, FAQ, and hundreds of hyperlinked examples.
Matt
> On Thu, Jul 7, 2011 at 12:20 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Wed, Jul 6, 2011 at 09:53, Adam Byrd <adam1.byrd at gmail.com> wrote:
>>> I do not want the transpose, but that is what is coming out as the
>>> solution. Both my tests show the correct original matrix, and both yield the
>>> transpose of the solution verified against Mathematica and the website from
>>> which I pulled the 4x4 matrix in test.cpp. Could it be related to the
>>> factoring?
>> The problem is that you are trying to solve with an AIJ matrix instead of
>> a DENSE matrix. MatMatSolve() calls MatGetArray(). Since this is serial and
>> you preallocated enough for a dense matrix, it goes through with no memory
>> errors. The storage format for MATAIJ (that happens to be dense) and
>> MATDENSE is transposed, so you see the transpose. If you make the solution
>> matrix dense, then it will work correctly.
>> --- a/test.cpp
>> +++ b/test.cpp
>> @@ -48,7 +48,9 @@ int main(int argc,char **args)
>> ierr = MatAssemblyEnd(identityMat,
>> MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> //Setup inverseMat
>> - ierr = MatDuplicate(testMat, MAT_DO_NOT_COPY_VALUES,
>> &inverseMat);CHKERRQ(ierr);
>> + ierr = MatCreate(PETSC_COMM_WORLD, &inverseMat);CHKERRQ(ierr);
>> + ierr = MatSetSizes(inverseMat, PETSC_DECIDE, PETSC_DECIDE, rows,
>> columns);CHKERRQ(ierr);
>> + ierr = MatSetType(inverseMat, MATDENSE);CHKERRQ(ierr);
>> ierr = MatAssemblyBegin(inverseMat,
>> ierr = MatAssemblyEnd(inverseMat,
>> PETSc should be more careful about matching types here.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110707/a725b928/attachment.htm>
