[petsc-users] Question for time dependent problems
Travis C. Fisher
travis.fisher at nasa.gov
Tue Jul 5 14:38:12 CDT 2011
I am wondering if there is a "right way" to set up preconditioning for
time dependent nonlinear problems (using precondtioned matrix free
SNES). For example, I want to use implicit Runge Kutta, and freeze my
preconditioner at the beginning of each step. Currently how I do this is:
Problem set up:
1. Specify nonzero structure of precondtioner matrix.
2. Specify MAT_NEW_NONZERO_LOCATION_ERR and MAT_KEEP_NONZERO_PATTERN.
Beginning of a time step (1st implicit stage of RK scheme):
1. Use MatZeroEntries on the preconditioner
2. Calculate and assemble preconditioning matrix
3. In the jacobian evaluation routine, use flag = SAME_NONZERO_PATTERN
(I'd like it to use the nonzero structure I've already specified)
Subsequent nonlinear solves in time step:
1. Use flag = SAME_PRECONDITIONER in the jacobian evaluation
In this way, I only initialize the preconditioning matrix structure
once. I am wondering if I have made any large mistakes here or if I am
misunderstanding the character of the solver?
Is there a tutorial case for this situation? I want to note that my
initial nonzero structure may contain entries that are zero, but may not
be zero in subsequent calculations. I am wondering what PETSC does with
these during ASM/ILU preconditioning? i.e. Does it remove them from my
originally specified nonzero structure?
I appreciate any direction you can give me.
Travis Fisher
