[petsc-users] Getting a copy of a PETSC vector into a user sequential vector
Satish Balay
balay at mcs.anl.gov
Fri Jan 14 16:13:44 CST 2011
VecGetArray() is defined to always look out of bounds - so if you use
a compiler flag to check for out of bound error - you will always get
this error.
Alternative is to use VecGetArrayF90() - and to use this correctly -
you should include petscvec.h90
Satish
On Fri, 14 Jan 2011, Ormiston, Scott J. wrote:
> We have been trying to use scatter to collect the entries of a PETSc solution
> vector into an ordinary sequential vector. We need this for our own
> post-processing and other calculations.
> We were able to get ex15f.F to create and solve a matrix. Then we added code
> from ex30f.F and we were able to get it to work. When we put the code into
> our own mainline, it fails with the run-time error message:
> 0: Subscript out of range for array xx_v (main-petsc.f95: 1649)
> subscript=261373973, lower bound=1, upper bound=1, dimension=1
> mpiexec has exited due to process rank 0 with PID 23105 on
> node mecfd01 exiting without calling "finalize". This may
> have caused other processes in the application to be
> terminated by signals sent by mpiexec (as reported here).
> Any ideas of what might be wrong? We believe the link libraries are the same
> between the two make files, and we just inserted the working example 15/30
> code into our existing, working mainline.
> For reference, an excerpt of the key code segments and the full relevent
> output are appended.
> Scott Ormiston
> =========================CODE EXCERPT===============================
> REAL*8 sol(NILU) !NILU is the length of the solution vector
> #include "finclude/petscsys.h"
> #include "finclude/petscvec.h"
> #include "finclude/petscmat.h"
> #include "finclude/petscpc.h"
> #include "finclude/petscksp.h"
> #include "finclude/petscis.h"
> #define xx_a(ib) xx_v(xx_i + (ib))
> PetscOffset xx_i
> PetscScalar xx_v(1)
> #include "finclude/petscvec.h90"
> PetscScalar, pointer :: xp_v(:)
> Vec seqV
> VecScatter scat1
> IS fromis, tois
> PetscInt from(12), to(12)
> Vec Vx,Vb,Vu
> Mat A
> PC pc
> KSP ksp
> PetscScalar PSv,one,neg_one
> double precision norm,tol
> PetscErrorCode ierr
> PetscInt PETSCi,PETSCj,II,JJ,Istart
> PetscInt Iend,m,n,i1,its,five
> PetscMPIInt rank
> PetscTruth user_defined_pc,Pflg
> external SampleShellPCSetUp, SampleShellPCApply, SampleShellPCDestroy
> ! Common block to store data for user-provided preconditioner
> common /myshellpc/ diag
> Vec diag
> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> ! ex15f.F code ...
> call KSPSolve(ksp,Vb,Vx,ierr)
> !-- put the solution from parallel vector vx into sol(*)
> do i=1,m*n
> from(i)=i-1
> to(i) =i-1
> end do
> call VecCreateSeq(PETSC_COMM_SELF,m*n,seqV,ierr)
> call VecSet(seqV,neg_one,ierr)
> if (rank.eq.0) then
> print *, "seqV OLD"
> call VecView(seqV,PETSC_VIEWER_STDOUT_SELF,ierr)
> end if
> call ISCreateGeneral(PETSC_COMM_SELF,m*n,from,fromis,ierr)
> call ISCreateGeneral(PETSC_COMM_SELF,m*n,to,tois,ierr)
> call VecScatterCreate(Vx,fromis,seqV,tois,scat1,ierr)
> call ISDestroy(fromis,ierr)
> call ISDestroy(tois,ierr)
> call VecScatterBegin(scat1,Vx,seqV,INSERT_VALUES,SCATTER_FORWARD,ierr)
> call VecScatterEnd(scat1,Vx,seqV,INSERT_VALUES,SCATTER_FORWARD,ierr)
> if (rank.eq.0) then
> print *, "seqV NEW"
> !------*.F version of VecGetArray
> call VecGetArray(seqV,xx_v,xx_i,ierr)
> write(6,*) 'after VecGetArray'
> write(6,*) 'n=',n, ' m=',m
> do PETSCi=1,m*n
> xx_a(PETSCi) = 100.0*PETSCi
> sol(i) = xx_a(i) + 1.55
> sol(i) = xx_v( xx_i + (i))
> end do
> call VecRestoreArray(seqV,xx_v,xx_i,ierr)
> !------*.f95 version of VecGetArray
> call VecGetArrayF90(seqV,xp_v,ierr)
> print*,ierr
> do i=1,m*n
> sol(i)= xp_v(i) - 5.0
> xp_v(i) = 100.0*i
> end do
> call VecRestoreArrayF90(seqV,xp_v,ierr)
> print*,'the f95 version of test solution vector is:'
> do i=1,m*n
> print*,sol(i)
> end do
> end if
> ! Free work space. All PETSc objects should be destroyed when they
> ! are no longer needed.
> call KSPDestroy(ksp,ierr)
> call VecDestroy(Vu,ierr)
> call VecDestroy(Vx,ierr)
> call VecDestroy(Vb,ierr)
> call MatDestroy(A,ierr)
> ! Always call PetscFinalize() before exiting a program.
> call PetscFinalize(ierr)
> =========================OUTPUT=====================================
> KSP Object:
> type: gmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-07, absolute=1e-50, divergence=10000
> left preconditioning
> using PRECONDITIONED norm type for convergence test
> PC Object:
> type: jacobi
> linear system matrix = precond matrix:
> Matrix Object:
> type=seqaij, rows=12, cols=12
> total: nonzeros=46, allocated nonzeros=60
> not using I-node routines
> seqV OLD
> -1
> -1
> -1
> -1
> -1
> -1
> -1
> -1
> -1
> -1
> -1
> -1
> seqV NEW
> 1
> 1
> 1
> 1
> 1
> 1
> 1
> 1
> 1
> 1
> 1
> 1
> after VecGetArray
> n= 4 m= 3
