[petsc-users] Getting a copy of a PETSC vector into a user sequential vector
Ormiston, Scott J. SJ_Ormiston at UManitoba.ca
Fri Jan 14 14:14:59 CST 2011
We have been trying to use scatter to collect the entries of a PETSc
solution vector into an ordinary sequential vector. We need this for our
own post-processing and other calculations.
We were able to get ex15f.F to create and solve a matrix. Then we added
code from ex30f.F and we were able to get it to work.  When we put the
code into our own mainline, it fails with the run-time error message:
  0: Subscript out of range for array xx_v (main-petsc.f95: 1649)
      subscript=261373973, lower bound=1, upper bound=1, dimension=1
  mpiexec has exited due to process rank 0 with PID 23105 on
  node mecfd01 exiting without calling "finalize". This may
  have caused other processes in the application to be
  terminated by signals sent by mpiexec (as reported here).
Any ideas of what might be wrong? We believe the link libraries are the
same between the two make files, and we just inserted the working
example 15/30 code into our existing, working mainline.
For reference, an excerpt of the key code segments and the full relevent
output are appended.
Scott Ormiston
=========================CODE EXCERPT===============================
   REAL*8  sol(NILU) !NILU is the length of the solution vector
#include "finclude/petscsys.h"
#include "finclude/petscvec.h"
#include "finclude/petscmat.h"
#include "finclude/petscpc.h"
#include "finclude/petscksp.h"
#include "finclude/petscis.h"
#define xx_a(ib)  xx_v(xx_i + (ib))
   PetscOffset     xx_i
   PetscScalar     xx_v(1)
#include "finclude/petscvec.h90"
   PetscScalar, pointer ::  xp_v(:)
   Vec             seqV
   VecScatter      scat1
   IS              fromis, tois
   PetscInt        from(12), to(12)
   Vec              Vx,Vb,Vu
   Mat              A
   PC               pc
   KSP              ksp
   PetscScalar      PSv,one,neg_one
   double precision norm,tol
   PetscErrorCode   ierr
   PetscInt         PETSCi,PETSCj,II,JJ,Istart
   PetscInt         Iend,m,n,i1,its,five
   PetscMPIInt      rank
   PetscTruth       user_defined_pc,Pflg
   external SampleShellPCSetUp, SampleShellPCApply, SampleShellPCDestroy
!  Common block to store data for user-provided preconditioner
   common /myshellpc/ diag
   Vec    diag
   call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
! ex15f.F code ...
         call KSPSolve(ksp,Vb,Vx,ierr)
!-- put the solution from parallel vector vx into sol(*)
   do i=1,m*n
      from(i)=i-1
      to(i)  =i-1
   end do
   call VecCreateSeq(PETSC_COMM_SELF,m*n,seqV,ierr)
   call VecSet(seqV,neg_one,ierr)
   if (rank.eq.0) then
      print *, "seqV OLD"
      call VecView(seqV,PETSC_VIEWER_STDOUT_SELF,ierr)
   end if
   call ISCreateGeneral(PETSC_COMM_SELF,m*n,from,fromis,ierr)
   call ISCreateGeneral(PETSC_COMM_SELF,m*n,to,tois,ierr)
   call VecScatterCreate(Vx,fromis,seqV,tois,scat1,ierr)
   call ISDestroy(fromis,ierr)
   call ISDestroy(tois,ierr)
   call VecScatterBegin(scat1,Vx,seqV,INSERT_VALUES,SCATTER_FORWARD,ierr)
   call VecScatterEnd(scat1,Vx,seqV,INSERT_VALUES,SCATTER_FORWARD,ierr)
   if (rank.eq.0) then
      print *, "seqV NEW"
      !------*.F version of VecGetArray
      call VecGetArray(seqV,xx_v,xx_i,ierr)
      write(6,*) 'after VecGetArray'
      write(6,*) 'n=',n, ' m=',m
      do PETSCi=1,m*n
         xx_a(PETSCi) = 100.0*PETSCi
         sol(i) = xx_a(i) + 1.55
         sol(i) = xx_v( xx_i + (i))
      end do
      call VecRestoreArray(seqV,xx_v,xx_i,ierr)
      !------*.f95 version of VecGetArray
      call VecGetArrayF90(seqV,xp_v,ierr)
      print*,ierr
      do i=1,m*n
         sol(i)= xp_v(i) - 5.0
         xp_v(i) = 100.0*i
      end do
      call VecRestoreArrayF90(seqV,xp_v,ierr)
      print*,'the f95 version of test solution vector is:'
      do i=1,m*n
         print*,sol(i)
      end do
   end if
!  Free work space.  All PETSc objects should be destroyed when they
!  are no longer needed.
         call KSPDestroy(ksp,ierr)
         call VecDestroy(Vu,ierr)
         call VecDestroy(Vx,ierr)
         call VecDestroy(Vb,ierr)
         call MatDestroy(A,ierr)
!  Always call PetscFinalize() before exiting a program.
       call PetscFinalize(ierr)
=========================OUTPUT=====================================
KSP Object:
   type: gmres
     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
     GMRES: happy breakdown tolerance 1e-30
   maximum iterations=10000, initial guess is zero
   tolerances:  relative=1e-07, absolute=1e-50, divergence=10000
   left preconditioning
   using PRECONDITIONED norm type for convergence test
PC Object:
   type: jacobi
   linear system matrix = precond matrix:
   Matrix Object:
     type=seqaij, rows=12, cols=12
     total: nonzeros=46, allocated nonzeros=60
       not using I-node routines
  seqV OLD
-1
-1
-1
-1
-1
-1
-1
-1
-1
-1
-1
-1
  seqV NEW
1
1
1
1
1
1
1
1
1
1
1
1
  after VecGetArray
  n=            4  m=            3
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110114/d2709f4e/attachment.vcf>
