[petsc-users] Using PETSc from MATLAB code, experimental
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Jan 13 13:23:21 CST 2011
   Michel
     Lisandro is exactly right. The key is building the .dll. If you are interested in pursing this we are eager to help but are not Windows experts in any way.
     1) are you using the GNU compiler or Microsoft?
     2) if you are using GNU you can try building with the same options as indicated in the docs. including the --with-shared-libraries flag. what happens?
          What is generated?
   Let us know and we'll go from there,
   Barry
On Jan 13, 2011, at 11:18 AM, Lisandro Dalcin wrote:
> On 13 January 2011 08:38, Michel Cancelliere <fernandez858 at gmail.com> wrote:
>> Hi Barry,
>> is Matlab under Windows with petsc-cygwin supported?
> Unlikely, we would need to build PETSc as a DLL... If anyone can
> manage to do that, then Barry's work should work out of the box.
> Or perhaps PETSc do build as a DLL under cygwin?
>> Thanks,
>> Michel
>> On Sun, Dec 26, 2010 at 5:17 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>  PETSc users,
>>>   It is now possible to write MATLAB programs (sequential) that use PETSc
>>> KSP, SNES, and TS solvers directly in MATLAB. The code is still experimental
>>> and incomplete. But if you are interested in trying it out, get the
>>> development release of PETSc
>>> http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html join the
>>> development mailing list petsc-dev
>>> http://www.mcs.anl.gov/petsc/petsc-as/miscellaneous/mailing-lists.html, read
>>> bin/matlab/classes/PetscInitialize.m, configure and make PETSc and join the
>>> fun. We are definitely in need of more developers for this code.
>>>   Barry
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
