[petsc-users] Using PETSc from MATLAB code, experimental
    Lisandro Dalcin
    dalcinl at gmail.com
    Thu Jan 13 11:18:35 CST 2011
On 13 January 2011 08:38, Michel Cancelliere <fernandez858 at gmail.com> wrote:
> Hi Barry,
> is Matlab under Windows with petsc-cygwin supported?
Unlikely, we would need to build PETSc as a DLL... If anyone can
manage to do that, then Barry's work should work out of the box.
Or perhaps PETSc do build as a DLL under cygwin?
> Thanks,
> Michel
> On Sun, Dec 26, 2010 at 5:17 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  PETSc users,
>>   It is now possible to write MATLAB programs (sequential) that use PETSc
>> KSP, SNES, and TS solvers directly in MATLAB. The code is still experimental
>> and incomplete. But if you are interested in trying it out, get the
>> development release of PETSc
>> http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html join the
>> development mailing list petsc-dev
>> http://www.mcs.anl.gov/petsc/petsc-as/miscellaneous/mailing-lists.html, read
>> bin/matlab/classes/PetscInitialize.m, configure and make PETSc and join the
>> fun. We are definitely in need of more developers for this code.
>>   Barry
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
