[petsc-users] Using PETSc from MATLAB code, experimental
Thu Jan 13 13:26:01 CST 2011
I suspect Matlab would work with MS dlls - and not cygwin/gnu dlls..
satish
On Thu, 13 Jan 2011, Barry Smith wrote:
>    Michel
>      Lisandro is exactly right. The key is building the .dll. If you are interested in pursing this we are eager to help but are not Windows experts in any way.
>      1) are you using the GNU compiler or Microsoft?
>      2) if you are using GNU you can try building with the same options as indicated in the docs. including the --with-shared-libraries flag. what happens?
>           What is generated?
>    Let us know and we'll go from there,
>    Barry
> On Jan 13, 2011, at 11:18 AM, Lisandro Dalcin wrote:
> > On 13 January 2011 08:38, Michel Cancelliere <fernandez858 at gmail.com> wrote:
> >> Hi Barry,
> >> is Matlab under Windows with petsc-cygwin supported?
> > Unlikely, we would need to build PETSc as a DLL... If anyone can
> > manage to do that, then Barry's work should work out of the box.
> > Or perhaps PETSc do build as a DLL under cygwin?
> >> Thanks,
> >> Michel
> >> On Sun, Dec 26, 2010 at 5:17 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >>>  PETSc users,
> >>>   It is now possible to write MATLAB programs (sequential) that use PETSc
> >>> KSP, SNES, and TS solvers directly in MATLAB. The code is still experimental
> >>> and incomplete. But if you are interested in trying it out, get the
> >>> development release of PETSc
> >>> http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html join the
> >>> development mailing list petsc-dev
> >>> http://www.mcs.anl.gov/petsc/petsc-as/miscellaneous/mailing-lists.html, read
> >>> bin/matlab/classes/PetscInitialize.m, configure and make PETSc and join the
> >>> fun. We are definitely in need of more developers for this code.
> >>>   Barry
> > Lisandro Dalcin
> > CIMEC (INTEC/CONICET-UNL)
> > Predio CONICET-Santa Fe
> > Colectora RN 168 Km 472, Paraje El Pozo
> > Tel: +54-342-4511594 (ext 1011)
> > Tel/Fax: +54-342-4511169
