[petsc-users] Using PETSc from MATLAB code, experimental
Michel Cancelliere
fernandez858 at gmail.com
Thu Jan 13 05:38:59 CST 2011
Hi Barry,
is Matlab under Windows with petsc-cygwin supported?
Michel
On Sun, Dec 26, 2010 at 5:17 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> PETSc users,
> It is now possible to write MATLAB programs (sequential) that use PETSc
> KSP, SNES, and TS solvers directly in MATLAB. The code is still experimental
> and incomplete. But if you are interested in trying it out, get the
> development release of PETSc
> http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html join the
> development mailing list petsc-dev
> http://www.mcs.anl.gov/petsc/petsc-as/miscellaneous/mailing-lists.html,
> read bin/matlab/classes/PetscInitialize.m, configure and make PETSc and join
> the fun. We are definitely in need of more developers for this code.
> Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110113/b174ceae/attachment.htm>
