[petsc-users] which version of openmpi for petsc-3.1?
    Satish Balay
    balay at mcs.anl.gov
    Wed Jan  5 10:18:05 CST 2011
One additional note with OpenMPI install:
OpenMPI defaults to installing shared libraries - but does not
use --rpath option within the mpicc wrapper - and requires user
to set LD_LIBRARY_PATH - so that mpicc is useable.
So make sure you do this before running PETSc configure [or install
openmpi static..]
Satish
On Wed, 5 Jan 2011, Satish Balay wrote:
> --download-PACKAGE=PACKAGE.tar.gz usually works only with the
> specified version with the URL listed in the corresponding PACKAGE.py
> However with MPI - you can install any impl/version separately with
> your desired compilers [and not use --download-mpich or
> --download-openmpi], and then configure PETSc with mpicc/mpif90 etc
> from this install.
> Satish
> On Wed, 5 Jan 2011, Jed Brown wrote:
> > Just use the most recent version unless you have a reason not to. PETSc does
> > not depend on any specific versions (or implementations) of MPI.
> > On Jan 5, 2011 7:55 AM, "Klaij, Christiaan" <C.Klaij at marin.nl> wrote:
> > The manual states:
> > "If one had to download a compatible external package manually, then the URL
> > for this package is listed in configure source for this package. For
> > example, check config/PETSc/packages/SuperLU.py for the url for download
> > this package."
> > But I cannot find anything like OpenMPI.py... Which version should I
> > download?
> > Chris
> > dr. ir. Christiaan Klaij
> > CFD Researcher
> > Research & Development
> > E mailto:C.Klaij at marin.nl
> > T +31 317 49 33 44
> > MARIN
> > 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
> > T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
